QUESTIONS!!!!!!!
Old Sep 7, 2006 | 01:01 PM
Acrfanatic's Avatar
Acrfanatic
Default QUESTIONS!!!!!!!
Every once in a while i notice that the floorspace of the backseat is wet. Why is this? Also my trunk is wet sometimes to/???? Please help if you can!
Old Sep 7, 2006 | 03:18 PM
01neon01's Avatar
01neon01
Default RE: QUESTIONS!!!!!!!
i have the same problem,well i havent had it in a while. its somewhere on the forum, but i think its got to do with the rear lights or something like that if i find the post ill let u know but i dont quite remember at the moment
Old Sep 7, 2006 | 04:18 PM
03neonRT's Avatar
03neonRT
There are a few reasons this could be happening...for the trunk it is more than likely the seals around the taillights are bad or not seating properly. For the backseat, its probably just the seals around the doors...
Is it a lot of water, like standing puddles, or just moisture?
Old Sep 7, 2006 | 08:31 PM
Acrfanatic's Avatar
Acrfanatic
Its not a puddle but its a lot of moisture. They are pretty soaked
Old Sep 8, 2006 | 01:13 AM
timplett's Avatar
timplett
I would guess it's most likely the tail lights. You seem to have the same exact problem I did. It's not usually suspected either because the trunk carpet will only get a little damp (it's a different type of carpet), while the rear seat carpet will get soaked. If the carpet is soaked I would definetely reccomend you pull it out and let it dry. It can be a pain, but your carpet will never dry properly while still in the car. A cheap fix for the tail lights is to put roof-sealant tar caulking where the gasket seats and re-install the tail light. You can use regular silicone if you want, but the tar will never set so it is easy to remove the tail lights again if needed.
