motegi wheels
Old Sep 9, 2006 | 09:35 PM
qnr69's Avatar
qnr69
Default motegi wheels
i put my wheels on for the first time today and 3 fit but one was not a match for the car wat do u guys suggest i do?
Old Sep 9, 2006 | 10:11 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: motegi wheels
what kind of wheels are they and are they all the same or is that last one different. also how did it not fit
Old Sep 9, 2006 | 10:17 PM
qnr69's Avatar
qnr69
they are motegi wheels # 2408 or 2407 u can look at them on motegis website and yes they were all the same wheels accept the last wheel i think the holls were spaced to far apart and the back of the wheel had a little bit of a different design please tell me wat to do im really frustrated
Old Sep 9, 2006 | 10:51 PM
spikeymikey87
measure the distance between the bolt holes on the wheels i beleave it should be 4 inches each. if not where did you get the wheels from because whoever sold them to you ripped you off
Old Sep 9, 2006 | 11:02 PM
qnr69's Avatar
qnr69
all the other wheels are perfect i actually bought them straight from motgi wheels i think its was a simple mix up of boxes
Old Sep 10, 2006 | 12:39 AM
spikeymikey87
its ok ive been trying to get rims from them since early july but everyone they send me either has something wrong with them or they are the wrong one so we are in the same boat. motegi actually recently has gone under new ownership i think so they are a mess. hopefully ill get the correct ones this week and you get your figured out. i looked at the wheels online that you are getting and they have a +42 offset so just make sure the tire isnt rubbing because that is a high offset and is not too easy to fit with a stock suspension and no wheel spacers. if you do have another suspension or wheel spacers you will be fine though
Old Sep 10, 2006 | 05:00 PM
qnr69's Avatar
qnr69
ive aready put them on and they all fit just that that one wheel has the wrong bolt pattern
