Info on CUSTOM interior
Old Sep 10, 2006 | 09:16 PM
unleashedcc's Avatar
unleashedcc
Default Info on CUSTOM interior
ok im goin to start on my interior, the theme its silver and black, now im not a bif fan of fiberglass, u need to know how to work it, takes time and those things i really dont have, so im thinkin of doin something else, but i still want the shiny smooth finish. I was told to prime the panels with a thick primer and drop 2 coats of paint then 2 coats of clear coat for protection and shininess, now my question is, wut type of primer do i need and wut paint? special primer for plastic? special paint or any type of spray paint? anyone with info let me know.
Old Sep 11, 2006 | 02:57 AM
timplett's Avatar
timplett
Default RE: Info on CUSTOM interior
You will need a special primer for plastic, regular primers usually don't stick. I would lay a coat of primer for plastic, then a coat or two of high-build primer to get a smooth surface (high-build primer is sandable), and then regular paint and clearcoat will work just fine.
Old Sep 11, 2006 | 07:59 PM
unleashedcc
any type of spray paint from advanceautoparts? any recommended brands? for primer, paint and clear-coats?
Old Sep 11, 2006 | 08:06 PM
unleashedcc
k wut about the armrest lid from the center console, its not really hard plastic like the other panels, its mushy like vinyl, should it be painted different? i neard its good to paint interior panels with a flexible clearcoats, tru or false, such thing?? im begining to strip my car tomorrow to start, so i need the most knowledge of the subject so it comes out proish
Old Sep 11, 2006 | 11:16 PM
timplett's Avatar
timplett
Well the paint for plastics should be flexible, because many plastics are. About the clearcoat, I'm not quite sure, but I know that automotive clearcoat is a little flexible, because if you get a minor dent in your door it won't chip off. I think the best thing would be to find a paint store near you, that sells paint and only paint, and the people working there should be able to point you in the right direction. Most likely that would be the best place to buy it too, seeing as that's what they specialize in.
Old Sep 14, 2006 | 04:57 PM
sxt_seven's Avatar
sxt_seven
why don't you go to NOPI.com they have inteior solutions, and you can get tips on how to paint the inside of the car.
ORIGINAL: unleashedcc
