5 Different Error codes all at once, 2001 neon HELP! I think there connected!
Old Sep 12, 2006 | 02:03 AM
Neon2Me's Avatar
Neon2Me
Default 5 Different Error codes all at once, 2001 neon HELP! I think there connected!
Ok, heres the thing I have 5 different error codes on the check engine light of my 2001 Neon SE. The car runs awesome, no problems, i recently installed a tack to my black wire with a grey streak on the side coming out of my ignition coil. But only read half RPMs as i thought so I unpluged it. I never cut the wire.
So as I was saying, the car runs awesome, cold air, high performance wires/plugs, K&N filter, exhaust, the works, but ever since i messed with that damn wire this have been going downhill. At first my engine was misfireing. So i replaced the plugs and it ran beautifuly, had the platinum ones for about 3 years so its about time it goes bad.
SO NOW THE CAR RUNS COMPLETLY FLAWLESS! But it has the check engine light on with the following codes:\
P1192 - IAT circuit LOW
P1193 - IAT circuit HIGH ?? How can it be low and high at the same time??
P0351- Ignition Coil No. 1 primary Circuit
P0352 Ignition Coil No. 2 Primary Circuit
P1388 Auto shutdown relay circuit
OK HOW CAN A IAT CIRCUT BE HIGH AND LOW! THERE TWO EXTREMES! And as i said the car runs awesome, but it says thats wrong? I want to fix them one by one, the simpiliest to the more expensive. Some one tell me what they know and they will be a GREAT help in keeping my neon going in the long run!
Thank you,
Andrew
Old Sep 13, 2006 | 02:18 AM
das2123's Avatar
das2123
Default RE: 5 Different Error codes all at once, 2001 neon HELP! I think there connected!
Reset the PCM and see if they come back.
Old Sep 19, 2006 | 02:14 AM
ewetho's Avatar
ewetho
IAT low means open circuit. IAT high means errant voltage to the circuit. Now they set one at a time. So if you had feed back into the system or unpluged witht he key on you get the idea.
Tach may have messed with coil primary side wiring.
So try a reset and see if they come back. IF SO then troubleshoot the first one out of th PCM first. Whatever it is.
