2000 Neon Lx Idle Problem
Old Sep 17, 2006 | 05:05 AM
kennyfung40's Avatar
kennyfung40
Default 2000 Neon Lx Idle Problem
my have problem when stop with gear , the RPM drop to 5 instead of 7 to 8. Car start have noise come out from engine compartment. RPM back tp normal 7 to 8 when I put the car to park. Anyone have ideal what wrong ? Please advise !
Old Sep 17, 2006 | 05:38 AM
bill14224's Avatar
bill14224
Default RE: 2000 Neon Lx Idle Problem
Many things can cause your car to idle too slowly in drive with your foot on the brake. Your car is 6 years old so if you haven't had the transmission fluid changed yet it's time to do it. Transmission fluid doesn't last forever despite popular opinion. Assuming there's nothing wrong with your transmission (which you'll find out soon enough if there is) check your air filter to make sure it's clean, and your spark plugs to make sure they're not worn or crusty. If your plug wires are original it's time to replace them too. Also, clean your PCV valve, or just replace it. (they're cheap) If that all looks good you need to check for intake leaks.
Arrive alive,
Bill
Old Sep 17, 2006 | 03:42 PM
ewetho's Avatar
ewetho
May also check out cleaning your throttle body. IAC passages are possibly partially blocked too.
