CAmshaft
Old Sep 17, 2006 | 11:22 PM
hertzog1284's Avatar
hertzog1284
Default CAmshaft
Well I just installed my new camshaft today. Its an Crane Cam 158-0012, and I installed new valve springs. Well I went to start it and it sputters and then dies. Once you get it started this loud clanking noise is coming from what I believe is the #1 cylinder. And the check engine light is on. Does anyone have an idea what may be wrong.
Old Sep 17, 2006 | 11:37 PM
tooslow's Avatar
tooslow
Default RE: CAmshaft
are you 400% you got the timing right.
Old Sep 18, 2006 | 12:42 AM
03neonRT's Avatar
03neonRT
ORIGINAL: tooslow
What he said...there is ZERO room for error.
Old Sep 18, 2006 | 12:49 AM
spikeymikey87's Avatar
spikeymikey87
yea and i believe the idle has to be set higher for that cam
Old Sep 18, 2006 | 10:23 AM
hertzog1284
I lined up the timing marks on the cam and crank, according to the haynes manual. Once it idles the noise quits down. But is very dificult to get started again.
Old Sep 18, 2006 | 04:17 PM
tooslow's Avatar
tooslow
just do compression check that will tell you if you bent valve it is alot easier than taking the head off
