help
hey my neon has been sitting for 2 and a half years we finally got it done so i drove it and it was very slow it also has semi bad gas and or needs to be driven more or is this how neons usually are any suggestions on wat to do?
well if you have the chance........your 0-60, as ur car is basically stock......, should be around 10-11 secs.
If ur much over those numbers then start to worry, but I mean don't expect too much. no matter what though you should definetly run some clean gas through and as said before injector cleaner wouldn't hurt at all.
When My car was stock I remember numbers like 11.4-11.6 sec for 0-60, but this wasn't completely accurate, I mean with a stopwatch and me driving this is about what I figured it to be, but somewhere in that vicinity should be normal.
