'04 VSS (Vehicle Speed Sensor) Signal
Old Sep 21, 2006 | 11:43 PM
LA_NEON_123's Avatar
LA_NEON_123
Default '04 VSS (Vehicle Speed Sensor) Signal
I'm trying to install a cruise control on my 2004 Neon SE. It'd help a lot if I could find the VSS (Vehicle Speed Sensor) signal wire. Does anyone know where that wire is?
Thanks in advance, for any help.
Old Sep 22, 2006 | 02:26 AM
timplett's Avatar
timplett
Default RE: '04 VSS (Vehicle Speed Sensor) Signal
The sensor should be near the output shaft of the transmission. There are 3 wires that run betweent he sensor and the PCM: the sensor ground (black/light blue), 8v power supply (orange), and the speed sensor signal (white/orange). This is according to the 2000 FSM, so they should be correct but there are some slight changes between models so I make no guarantee.
Old Sep 22, 2006 | 02:21 PM
LA_NEON_123
Thanks for your reply. Do you happen to know the number of pulses per mile? The transmission is automatic. And what is the PCM and where is it located?
Old Sep 22, 2006 | 02:48 PM
timplett's Avatar
timplett
PCM = Powertrain Control Module a.k.a. the computer. I am just looking off of the factory service manual, so I am unsure of where the PCM is located. I'm sure there are those on this site that will know. The factory service manual does not give any specs for pulses per mile.
Old Sep 22, 2006 | 03:38 PM
LA_NEON_123
OK. Thanks for all your help.
