fog lights?
Old Sep 30, 2006 | 04:50 AM
campbellsoup's Avatar
campbellsoup
Default RE: fog lights?
its a dealers option cause mine didnt come with them
i will take some pics tomorrow and post them
Old Oct 1, 2006 | 06:44 PM
SupermanNeon's Avatar
SupermanNeon
I bought some yesterday but i couldnt find a hole in the firewall to run the wires through for the switch can someone help me out maybe by some pics?? and how do i run the wires? the instructions just say run here, run there..not being specific..
Old Oct 1, 2006 | 06:52 PM
timplett's Avatar
timplett
Most of the time you'll have to drill your own hole through the firewall. You can get firewall grommets that will seal the wire to the hole. Or, like I did for my amp power wire, if it's a round wire, drill the hole just slightly smaller than the wire, so it will be snug, but not tight enough to wreck the insulation.
Old Oct 1, 2006 | 06:54 PM
unleashedcc's Avatar
unleashedcc
well i did mine simple, i didnt use a switch. i just grabbed each positive from the light and connected it to the positive of the bumper lights (left with left, right with right) same with the negative. of coarse i didnt split it, i just cut the lightbulb so now i have no bumper lights, didnt really like em anyways. if u run the fog and bumper lights the lights might not be strong enough. if u want the switch, the firewall hole is right behind the steering wheel, at least for the 00-02. i just ended up taking and cutting that rubber housing because i have a few things runing there, i just put thick layers of electrical tape ont he edges so they int sharp. if u decide to keep the rubber housing then its hard but doable, just tape the switch cables to a long screw driver and stick it true and just get the cables from the inside. any other question let me know. good luck
Old Oct 1, 2006 | 09:17 PM
SupermanNeon
Ok i looked ..I saw a hole to the left of the steering stuff...has 2 fat cables running through and 1 small..Is that what your talking about?, and if so can i see where does it come out inside the car? can i see if just buy flashing a light up from above the pedels? And i just cut the rubber thing alittle till i can see through??? Thanks
Old Oct 1, 2006 | 11:01 PM
unleashedcc
well its night here in fl and its rainin so i cant help u out tonight, my best idea is put a long screwdriver through to see if u see it from the other side.
Old Oct 1, 2006 | 11:32 PM
SupermanNeon
Yea i live in south florida and its pouring rain now also..heh..ill try that tho..Thanks ill post if i cant figure it out.!!
Old Oct 1, 2006 | 11:44 PM
unleashedcc
word? wut part, im in miami, u know wut, im gonna start up a post lol
Old Oct 2, 2006 | 02:04 AM
Izero's Avatar
Izero
so what do you guys think is the best source to wire the fog lights to?
Old Oct 2, 2006 | 02:20 AM
SupermanNeon
I wanna use a switch to be able to turn them off and on..Ima wire the ground for the lights outside to a ground i found on the inside top of my wheel well in my engine bay..and the ground and live wires inside the car for the switch ima go with attaching them to the rado..Ive already done it with my radar so why not!
