fog lights?
Old Oct 4, 2006 | 01:54 PM
  #41
Izero's Avatar
Izero
Default RE: fog lights?
i think it goes on the inside right under the dash......... so just put the seat all the way down and push them all the way back and lay upside down and you should see an empty space under the dash....... and just a side note its not great to drive around with the lights on at night b/c it effects your night vision.....
Old Oct 4, 2006 | 08:01 PM
  #42
SupermanNeon's Avatar
SupermanNeon
though you can still see the brackets alittle..its only when u bend down and look..straight on its not bad and looks alot better then before..I play on adding a aftermarket bodykit later so i wont use these anymore anywayz..so no big deal!!
Old Oct 5, 2006 | 04:37 AM
  #43
camlen1098's Avatar
camlen1098
ORIGINAL: SupermanNeon
what is it screwed into..i couldnt find anything but screwing it in, out in the open right under the dash..had ti there 1 night and my girl was going nuts..said it bothered her eyes..
When ur sittin in the passerger seat you can't see the tubes directly, its hard to tell that from the pic but they are behind a piece of the dash... I actually used Super Glue to put 'em up, works awesome and it looks clean. no ties or anything.
When it bothered her eyes did it look something like my display pic?
Old Oct 5, 2006 | 09:47 AM
  #44
SupermanNeon
ORIGINAL: camlen1098
No cuz you were able to see the tube..Ima have to take a look today, Does anyone know how much Chit! you can splice to the back of the radio before something is overloaded..Right now i only have my radar but i was thinking of 2 neon tubes which i dont use but are under my seats right now.
Old Oct 5, 2006 | 08:21 PM
  #45
timplett's Avatar
timplett
Just splice a relay into the back of the radio, then you can pull power from the fuse panel but have it switched through the radio.
