engine sawp
Old Sep 27, 2006 | 03:58 PM
yellow neon's Avatar
yellow neon
Default engine sawp
I have 2003 sxt neon. Does anyone know how to swap the 2.0 engine for the srt-4 engine (2.4L). will it just drop in or(besides new computer) do i need different parts to put the engine in such as new engine mounts.
Old Sep 27, 2006 | 04:10 PM
das2123's Avatar
das2123
Default RE: engine sawp
This is some info that I have:
ORIGINAL: Diablo0
Engine and Tranny (duh)
Complete Engine Wiring Harness
Complete Engine Bay Wiring Harness
Power Steering Pump, lines, and cooler
Clutch master and slave cylinder
Clutch/Brake Pedal assembly
Intercooler Piping
Intercooler
Radiator Hoses
Tranny, Upper and Lower Motor Mounts (the holes are larger on the the upper and lower mounts for larger bolts and the tranny mount is completely different)
SRT PCM (wont' need the bracket with 03+)
Axles (and half shaft if it isn't on the engine)
Coolant Bottle
Fuel Line from tank to engine bay
Fuel Pump
Flex Fuel line from solid fuel line to fuel rail
Short evap hose that comes from the purge valve
All vacuum lines and the 3 selonids
o2 Sensors
Turbo Housing + o2 Housing
Lower Control Arms (they're stronger yet the same in shape)
Sentry Key Module + Key that matches the PCM VIN number.
Radiator (aren't totally sure if this is an absolute need)
Radiator Fans (it's a dual fan setup)
Shift Cables
Body Harness - fixes NVLD code (P0499)you will have on 00-02 swaps, also possibly fixes P0508 and P0688 codes.
If you plan on using the front brake setup you'll need the following
SRT Power steering rack (it's shorter)
Knuckles
Flexiable Brake Lines
Calipers
Rotors
Old Sep 27, 2006 | 04:24 PM
yellow neon
thanks that helps alot
Old Sep 28, 2006 | 10:54 AM
nicks2kes's Avatar
nicks2kes
it takes alot of time, money , and patience. also just about every power/air tools u can think of.
Old Oct 3, 2006 | 05:48 PM
yellow neon
trust me i have all the tools i need except a lift
