NEED HELP!!! 2001 Neon Stalls & Jerks when I press on gas
Old Oct 4, 2006 | 01:17 AM
Flaviuslc's Avatar
Flaviuslc
Default NEED HELP!!! 2001 Neon Stalls & Jerks when I press on gas
when i press the gas to get going it jerks and stalls when i try to gain speed.??? & check engine light is on as well?? Please Help.
Old Oct 4, 2006 | 01:29 AM
camlen1098's Avatar
camlen1098
Default RE: NEED HELP!!! 2001 Neon Stalls & Jerks when I press on gas
What was the code that came up with the engine light?
Old Oct 4, 2006 | 01:37 AM
fraggle_a's Avatar
fraggle_a
Yea.
Get the engine light code and check on the pinned message above for the error message.
Sounds like a fule feed issue though.
Old Oct 4, 2006 | 11:47 PM
kayakman's Avatar
kayakman
Also check intake manifold for oil
cheers
Kayakman
Old Oct 4, 2006 | 11:56 PM
sxt_seven's Avatar
sxt_seven
mine did the same thing, all i did was change the thorttle sensor, and it stop. maybe it's that!
Old Oct 5, 2006 | 02:49 AM
ewetho's Avatar
ewetho
If you can get scan data check your MAP sensor as well.
