Dyno run
Old Oct 10, 2006 | 02:02 AM
JTM78's Avatar
JTM78
Default Dyno run
Pulled a dyno run on a superflow inertia dyno friday. I pulled a 2.0 sohc with a 40te transmission with a final drive ratio of 3.94. The pulls where from 35 mph to deceleration. The first pull was 79hp to the wheel and the second was 81hp to the wheel ( the car is stock except for the short ram intake, some plugs, and wires). I would like to know if you have done a dyno run with your car, your hp, and the final drive ratio because I think my ratio is wrong. Any information would help greatly!
Old Oct 10, 2006 | 02:07 AM
spikeymikey87's Avatar
spikeymikey87
Default RE: Dyno run
umm wow thats not a civic right...just messing with you but there is something wrong, i cant begin to guess what it is though sorry
Old Oct 10, 2006 | 02:16 AM
JTM78's Avatar
JTM78
I forgot to post the run was done in 3rd aka drive the ratio I'm asking about is for this gear.
Old Oct 10, 2006 | 12:58 PM
das2123's Avatar
das2123
ORIGINAL: JTM78
I believe 3rd gear is 1.36 for all neon manual trannies.
Old Oct 10, 2006 | 01:31 PM
JTM78's Avatar
JTM78
Your thinking about the gear ratio and it 1:1 in 3rd gear. I'm looking for the final drive ratio and it a automatic any ways.
Old Oct 10, 2006 | 01:42 PM
das2123's Avatar
das2123
The 41TE has a 3.91 Final Drive.
Old Oct 10, 2006 | 04:53 PM
03neonRT's Avatar
03neonRT
A base Neon should be pulling roughly 100-110 at the wheels...but many many things contribute to why a dyno reads how it does.
Old Oct 11, 2006 | 01:10 AM
nicks2kes's Avatar
nicks2kes
i would say it sounds a little low to normal. 2.0 neons have about 80-100 hp at the wheels
Old Oct 11, 2006 | 01:23 AM
clean_sx's Avatar
clean_sx
i use the theory that on a neon, you lose 13% on a mtx, and double that to 26% for atx . that is pretty much the norm for any vehicle, when dodge said the neon had 132hp, thats at the crank so just take off the applicible loss and you have a rough number for HP
Old Oct 11, 2006 | 01:56 AM
95neonriceeater's Avatar
95neonriceeater
the wheel horsepower is between 10-15% less than the crank on any car
or almost any
so yea 13 sounds right
