need someone with a 2003+ neon
Old Oct 20, 2006 | 12:39 AM
SupermanNeon's Avatar
SupermanNeon
Default need someone with a 2003+ neon
I just switched out a speedo from a wrecked 2003+ neon, poor car that i got it from had only 15,xxx miles on it. heh but anywayz my question is when i turn it on everything works great..it has a tach and everything..but there is a little red light to the right of the tach above the fuel gauge that lights up about 1 min after the car is turned on..Does anyone know what it is becuz i looked at it during the day and there wasnt any icons really close to it...PicArrow points at it hope its big enough top right coner
Old Oct 20, 2006 | 12:52 AM
03neonRT's Avatar
03neonRT
Default RE: need someone with a 2003+ neon
Thats the sentry key indicator button...your car probably doesnt have the sentry key security feature but the Neon that the cluster came out of did have the sentry system...it wont hurt anything the cluster is just freakin out because its not detecting the SKIM...
Old Oct 20, 2006 | 01:34 AM
SupermanNeon
So i should be ok? I like the way this looks so i dont wanna change it heh! Thanks for the info
Old Oct 20, 2006 | 01:47 AM
03neonRT's Avatar
03neonRT
Yeah there shouldnt be any problems at all...if you really want just pull out the bulb for it...problem solved.
Old Oct 20, 2006 | 01:18 PM
SupermanNeon
Thanks
