Compression Ratio
Old Nov 3, 2006 | 05:46 AM
FreedomFighter22's Avatar
FreedomFighter22
Default Compression Ratio
I am Rebuilding an SRT4 engine block from scratch. It is going to be for racing and show. Stock compression ratio is 8.1:1 should i go with a higher or lower compression ratio on this performance block.
Old Nov 3, 2006 | 02:49 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: Compression Ratio
if you wanna push a lot of boost, i would go lower. ask on the srt-4 section though they might have more info on it good luck with the build. i'm building a 2.0L
Old Nov 3, 2006 | 10:10 PM
fullbuilt's Avatar
fullbuilt
dont go lower. if you drop down youll need a tow truck to get off the line. an 8.6 JE is perfect. if you want to boost into the mid 20s then you want to watch your fuel. get an accel and a lap top. as long as your pressure is perfect you could run 10.5lbs into the 20s.
