Starter Install
Old Nov 4, 2006 | 04:45 AM
laidlaw897's Avatar
laidlaw897
Default Starter Install
How easy or hard is it to install a starter on a 98 Neon SOHC?
Old Nov 4, 2006 | 01:17 PM
winsettz's Avatar
winsettz
Default RE: Starter Install
Haynes says to prop up the car on jackstands and to support the engine & transaxle to prevent "rotation", then to remove the engine front mount bolt from front crossmember mounting bracket to lower the front of the engine for better access to starter motor accessory. Then it's just "remove mounting bolts and detach the starter"...remove it from the bottom of the vehicle.
Edit: 98 Neon is 1G dude. ;p
