No Compression
2001 Neon, 2.0K 16V SOHC, 130,000 miles.
Stuttered, stalled for a while, replaced plugs & wires & seemed OK. Daughter was driving and started running REALLY rough. Took it to local shop. 3 Cylinders OK, 1 cylinder has NO compression and compression check shows pressure going to crankcase. Questions:
1. What could have caused this ? 130,000 miles isn't a lot, and oil was changed per factory specs.
2. Is it worth fixing ?
3. Where can I get a used motor or a re-built motor?
4. If I don't fix it, what would it's value be ? I'm guessing maybe $500.00 ?
Really kind of frustrated as car was paid off last may
cant say why without ripping it apart as far as woth to fix it goes by wether you can swap it yourself wreck yards are a great place to check. if you do it yourself the deal should cost around $500 if you take it to a garage $3000. If you were closer Id buy it for $500.
