transmission leaking can someone please help!!
Old Dec 10, 2006 | 12:07 AM
brandonba214's Avatar
brandonba214
Default transmission leaking can someone please help!!
i have a 2002 dodge neon and the automatic transmission is leaking! its leaking right under the pan the bolts are torqued and the thing is... i have been told it coming from above and running down the pan does anyone have any ideas where it is coming from. i changed the soleniod gasket and i thought that would fix it but that didnt do a damn thing. can the solenoid be bad by its self? please help thank
brandon
by the way its a big puddle!
lines are ok
pan is good
coming from top
Old Dec 10, 2006 | 01:42 PM
mike9fore's Avatar
mike9fore
Default RE: transmission leaking can someone please help!!
Possible Head Gasket if its coming from the top......But, don't qoute me on that......
Old Dec 10, 2006 | 05:35 PM
brandonba214
i found out what it was there is a solenoid that is right next to the transmission, its under the air cleaner well that was the problem, i am going to replace the solenoid because its the problem. dodge told me the part was like 268.00 and some change lol! anyways thanks
my next question would be is are the mounts that hold the engine and transmission hard to replace? can someone tell me that?
thanks
brandon
