check this out
Old Dec 13, 2006 | 12:41 AM
qnr69's Avatar
qnr69
Default check this out
this thing actuallu looks legit it does look like a car supercharger and its plastic so it doesnt heat but it is probably junk http://cgi.ebay.com/ebaymotors/Dodge...QQcmdZViewItem
Old Dec 13, 2006 | 12:50 AM
spikeymikey87's Avatar
spikeymikey87
Default RE: check this out
its **** dont get it there have been a lot of things about these and the only one that might get you 1/2 lb of boost and that one is like 500 and requires like 3 car batteries in your trunk and can only be used for 15 sec
its turbo or nothing no cheap way out (ive looked pretty hard for one trust me )
Old Dec 13, 2006 | 02:06 AM
fullbuilt's Avatar
fullbuilt
1/2 boost yes but they dont kill your bat that bad. but they dont hold up well under pressure. neber use it with high compresson or a turbo
Old Dec 13, 2006 | 02:54 AM
04 mo neon's Avatar
04 mo neon
NO NO AND Another NOOOOOOOOO.
You see those screws in the picture of it, my friend (kinda) for fun sanded them off so it would work in his "moms" 04 hyundai elentra, worked for a few minitues about 3 hp gain and clank clank, a screw went into the head f'ed up a valve and a pistion, end result, 1,500 dollars in repair at the dealership. lol But seriously not worth the risk man.
Old Dec 13, 2006 | 02:14 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
well, interesting concept, but figure 2.1psi???? naw. even if it makes it to the engine (which it will probaby leak out)
2.0 L engine, 14.4 atmospeheric pressure (roughly), so 14.4+2.1=16.3
2.0 = ??
14.1 16.3
so whats your new 'displacement equivelant'? considering the N/A motor is completley efficient adjusting the a/f mixture?
roughly 2.31. so it would be like a n/a 2.31 L motor. like i said, good concept but i dont think reality would be so kind on a dyno.
04, you said it actually sucked a loose screw into the motor? that sucks!
there is so much JUNK on fleebay, need to be careful!!!
if you dont mind im going to post this link somewhere else and get some more laughs.
Old Dec 13, 2006 | 04:03 PM
spikeymikey87
you wont even get to a 2.3Lmotor because it doesnt bring you out of vaccuum once you get out of vaccuum then you make power
Old Dec 13, 2006 | 06:19 PM
flamingpinhead
Section Moderator
not to mention pushing in even hotter air
Old Dec 13, 2006 | 07:22 PM
04 mo neon's Avatar
04 mo neon
Yeah I thought it was one of the funniest things I'd ever see happen, even though I wasn't actually their when it happened, I was there when for some stupid reason he decided to gind off the screw to make it work it his moms car. Oh mind you this was someones elses "fan/supercharger". That guy drives a escort zx2 which currently dosn't run anymore, and he has a seat that he f'ed up on drilling the holes on so it wobbles. A bunch of smart guys if you ask me, which I guess makes since b/c he drives a MKIII supra, that is a p.o.s. and now runs after 17g's of work paid for by his mom, and it's still an N/A making only 230whp, lol. He's something else, I just thought you guys should know that. Everything he touches something bad happens to.[sm=boohoo.gif]
Old Dec 13, 2006 | 08:09 PM
chazlewood75's Avatar
chazlewood75
What's his name and location so I KNOW not to drive my car through his town.
Old Dec 13, 2006 | 08:58 PM
spikeymikey87
hey dont hate on the mkiii supras theyre still faster then your neon
