Taillight???
Old Dec 13, 2006 | 05:04 PM
goldberg's Avatar
goldberg
Default Taillight???
Recently, i having problem with passenger side taillight. It's NOT working. I try changing bulb, but still not working. The odd thing is it works when unlock my car with remote, but not working when i hit brake or signal. Any Ideas??? Thx in advance.
Old Dec 13, 2006 | 05:21 PM
chazlewood75's Avatar
chazlewood75
Default RE: Taillight???
Have you checked your fuses yet? I swapped out headlights once because only one worked. After swapping them both, the one still didn't work. I took it back to the dealership to have them look at it. Turns out that there is a left and right fuse for the headlights. I would check the fuses.
Old Dec 13, 2006 | 05:35 PM
goldberg's Avatar
goldberg
There is no fuse for rear taillight....
Old Dec 13, 2006 | 06:18 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
wiring problem perhaps or maybe a relay somewhere? just strange that it DOES work whith the remote but not with the switches.
Old Dec 13, 2006 | 07:24 PM
04 mo neon's Avatar
04 mo neon
Yes there is a fuse for the tail light check again.
Old Sep 3, 2007 | 07:56 PM
chazlewood75
Did you figure this one out yet? Mine doesn't work when I use the remote or when I turn the headlights on. They brake lights work though. I inspected all fuses and none are burned out.
Old Sep 3, 2007 | 08:35 PM
spikeymikey87's Avatar
spikeymikey87
did you check the fuses in the engine bay?
Old Sep 3, 2007 | 08:58 PM
chazlewood75
I just did. They are all good. What rear lights come on when you turn the headlights on? That is my main problem. I don't have rear lights for night driving.
Old Sep 3, 2007 | 09:38 PM
Mike594sxt's Avatar
Mike594sxt
Get a tester light and touch on all the fuses to make sure they are even getting power. They can all be not blown, but if they're not getting any power in the first place, they aint doin ****.
