PLEASE HELP!!
Old Dec 17, 2006 | 11:33 PM
ttushk's Avatar
ttushk
Default PLEASE HELP!!
ok so the problem is that the key will not turn at all as though the column is locked. upon pressing the button to shift there is a click from the steering column. battery is fully charged nothing else is wrong. please help me! it appears that the car does not know it is in park
Old Dec 18, 2006 | 12:02 AM
tooslow's Avatar
tooslow
Default RE: PLEASE HELP!!
ok here is what you dois just wigle the steering wheel while try too turn the key it should turn
Old Dec 18, 2006 | 12:11 AM
ttushk's Avatar
ttushk
i tried that as well for quite a while and nothing, if i disconnect the battery will it reset the tranny so it thinks it's in park again?
Old Dec 18, 2006 | 01:49 AM
spikeymikey87's Avatar
spikeymikey87
wait is the key stuck in the column or you cant get it started
Old Dec 18, 2006 | 01:54 AM
LowSlowNeon's Avatar
LowSlowNeon
ORIGINAL: ttushk
Probably not. But you can try it. Resetting won't hurt anything.
Old Dec 18, 2006 | 03:30 AM
ttushk's Avatar
ttushk
when i put the key in it wont turn at all either way, i can pull it out again though so it's not stuck in the ignition.
Old Dec 18, 2006 | 03:35 AM
spikeymikey87
hmm it might be the tumblers need replacing has anything happened to it recently accident? shove a screwdriver in there? im assuming the shifters in park if not take center console off and release the locking clip on shift interlock cable so you can shift it to park
Old Dec 18, 2006 | 07:52 PM
Ix Elit3 xI's Avatar
Ix Elit3 xI
thats been happening to my moms car (POS buick rendezvous) happened not 30 min ago lol.
Just turn wheel to one side and hold it there with some force and just turn the key back and forth kinda hard and it will kick over.
Not sure what makes it do that but just a little brute force will always prevail.
Old Dec 18, 2006 | 08:44 PM
chazlewood75's Avatar
chazlewood75
Or you might call a locksmith.
Old Dec 18, 2006 | 10:42 PM
35ruger's Avatar
35ruger
try your spare key. I had a key wear out before.
good luck,Dennis
