i have a prob with shifting
Old Dec 20, 2006 | 03:28 PM
jordan123's Avatar
jordan123
Default i have a prob with shifting
i have a 2004 dodge neon stx with a bogging prob when i shift from 1st to 2nd i will hit the gas it will start to go and then it will quit, the rpms will drop and it will not go but then it will start to climb back up after all that does anyone eles have that prob??? the dealer cant find the prob and cant fix it they just put a O2 sensor on it and said that will fix it and it didnt, also flashed a computer didnt fix it now they have a recorder on it and are goin to try that i just want to know if anyone has had that prob and what did they do to fix it????
Old Dec 21, 2006 | 03:01 PM
Pablodragon's Avatar
Pablodragon
Default RE: i have a prob with shifting
seems obvious, u probably have already been thru this... but I had the problem and replaced the plugs and wires and now all is good
Old Dec 21, 2006 | 03:24 PM
GrApHite03's Avatar
GrApHite03
My 03 has always done this... I've yet to figure out the problem. I've done the above and almost everything else. My fix was to rev out first a bit longer. It would only happen to me when i granny shifted first to second. I never shift under 3k on the tach.
BTW, most 03+ do it... your not alone.
k3v
Old Dec 21, 2006 | 05:08 PM
Izero's Avatar
Izero
time for new wires and plugs......
Old Dec 21, 2006 | 06:21 PM
LowSlowNeon's Avatar
LowSlowNeon
New wires and plugs doesn't fix it. Mine does it from rarely...but still once in a great while it will. I usually just give it more gas, and when it goes, it GOES.
Old Dec 21, 2006 | 06:22 PM
04 mo neon's Avatar
04 mo neon
I seem to find that a lot of our cars are having this boggin problem, my car kinda does it but not really noticable like your guys, my guess would be the Throttle position sensor, b/c alot of them seem to go bad. The wires would cause you car to not run as crisp as it should. My only other guess would be the ecu but u said you had your's reflashed so I dont really have another possibility.
Old Dec 21, 2006 | 06:41 PM
Ix Elit3 xI's Avatar
Ix Elit3 xI
GO AUTO!!!!! yaya
Old Dec 21, 2006 | 07:11 PM
tooslow's Avatar
tooslow
there is a tsb for this on the 03r/t but all they do is reflash the ecu
Old Dec 21, 2006 | 10:55 PM
03neonRT's Avatar
03neonRT
ORIGINAL: tooslow
Yep my R/T used to bog between 1st and 2nd then i got that TSB freflash done...its been 10,000 miles and it hasnt done it ever since.I think its for all 2003 Neons though, not just the R/Ts...but i havent read the actualTSB in a while so I could be wrong.
Old Jan 18, 2007 | 07:27 PM
jordan123's Avatar
jordan123
anyone call dodge about this? i called and they said they have never heard of this prob and told me to go to another dealer...
