reverse lights not working
Old Jan 6, 2007 | 08:58 PM
tjf150's Avatar
tjf150
Default reverse lights not working
I have a 2000 Neon, Auto. My reverse lights are not working. I have replaced the bulbs, and the back-up switch on the tranny. Lights still don't work, any help before i take to a mechanic. Thanks
Old Jan 7, 2007 | 03:53 PM
neisg1's Avatar
neisg1
Default RE: reverse lights not working
Check fuse #7 it's 10A. also make sure the bulb sockets are properly grounded. Use a test light on the trany switch, with the ignition in the run position there should be 12v on the white wire and when in reverse also on the vio/blk wire that runs to the lights.
