Visit too the Dealership....
Old Jan 7, 2007 | 09:11 PM
PAGODA's Avatar
PAGODA
Default Visit too the Dealership....
Happy New Years to all and hello there,
how is everyone on here?
i made a visit to my local dealership for some regular Maintenance(oil change etc...)
they gave me a detailed List of what has to be done with it. i was wondering if i can have some Input on it all.
THANK YOU in advance !!
here is the report:
Needs 2 Rear Wheeled Cylinders $210 CDN (leaking)
Needs Left Lower Control Arm Bushing $200 CDN
Left Front Caliper starting to stick and wear one pad quicker thna the other (approx 35%Front and 55%Rear)
Old Jan 7, 2007 | 09:21 PM
03neonRT's Avatar
03neonRT
Default RE: Visit too the Dealership....
How many miles and what year is your Neon? The control arm bushing replacement is faily common and the sticking caliper is something that usually happens with high mileage or age. I'm not really sure what the leaking "rear wheeled cylinders" are though...
Old Jan 7, 2007 | 11:04 PM
ewetho's Avatar
ewetho
Brake fluid leaks are not good. Are you having to add brake fluid once in a while??? You should pull a wheel and the drum and look and see if you have fluid in the shoes or just under the rubber boots of the wheel cylinder. Some under the boot is normal as the brake fluid actually lubricates the pistons.
Calipers probably just need a quality brake job with the slides being thoroughly cleaned and lubricated. Might even get a brush to clean out the caliper slide receptors.
Control arm bushings happen and it is a great time to go POLY!!!
