MAF location
Old Jan 22, 2007 | 09:09 AM
cgerdes97's Avatar
cgerdes97
Default MAF location
I am looking for the MAF (mass air flow) sensor. I believe it is on the throttle body, but there are two sensors on there.. one on top near the throttle cable and one on the bottom.. I am not quite sure which one it is, any ideas?
Thank you
Old Jan 22, 2007 | 04:02 PM
tooslow's Avatar
tooslow
Default RE: MAF location
the map senser is on the bottum of the intake manifold
Old Jan 22, 2007 | 04:09 PM
fullbuilt's Avatar
fullbuilt
all the way to the left on the other side as the throttle body
Old Jan 22, 2007 | 07:36 PM
spikeymikey87's Avatar
spikeymikey87
there is none duh
Old Jan 22, 2007 | 08:16 PM
qnr69's Avatar
qnr69
are u having problems with it cause so am i [:'(]
Old Jan 22, 2007 | 08:45 PM
spikeymikey87
no really though neons do not have a mass air flow sensor it uses the map sensor instead
Old Jan 22, 2007 | 09:00 PM
fullbuilt's Avatar
fullbuilt
ya but you know what hes lookin for.
Old Jan 22, 2007 | 11:19 PM
spikeymikey87
no idea what hes lookin for anyway what and y are you lookin for the maf? there is an iat on the tb
Old Jan 23, 2007 | 10:19 PM
ewetho's Avatar
ewetho
MAF that would be a calculated value in the computer base on the IAT(Located before the throttle body), the TPS (located on the throttle body), and the MAP sensor located on the manifold.
