2005 Neon SRT intermiten starting problem
Old Jan 25, 2007 | 10:12 PM
79LRT's Avatar
79LRT
Default 2005 Neon SRT intermiten starting problem
Wifes neon has 15300 miles on it . and sometimes it wont start unless you feather the gas while cranking it over. Its very random maybe once a month. It did it twice yesterday so made an appointment to dealer and it didn't do it today. Also they said no codes came up so nothing they could do. Thanks for any help.
Old Jan 25, 2007 | 11:04 PM
fullbuilt's Avatar
fullbuilt
Default RE: 2005 Neon SRT intermiten starting problem
if thats the case you might has an evap leek thats small enough not to be picked up by the pcm, when you turn your key leave it on run for 2sec before cranking
Old Jan 25, 2007 | 11:20 PM
spikeymikey87's Avatar
spikeymikey87
yea i have that problem with my sxt. just hold the key in on for a few sec before yyou try to crank it over
Old Jan 26, 2007 | 11:12 AM
79LRT's Avatar
79LRT
Thanks Guys.
Old Jan 27, 2007 | 02:10 AM
ewetho's Avatar
ewetho
Could be either the IAC not responding properly or a fuel pressure regulator not holding pressure. Possible injector leakdown too. With low miles like that get it over to the dealership and have them fix it. That is what they are for.
Old Jan 28, 2007 | 10:15 PM
iamamp3pimp's Avatar
iamamp3pimp
i agre w the above poster. whatever it is, its warrantied, and there is no reason that they shouldnt be able to find the problem.
i hate intermittent though,
