torn motor mount?
Old Jan 27, 2007 | 09:37 PM
blk94z28's Avatar
blk94z28
Default torn motor mount?
I have done a search and really could not find my answer. My front upper motor mount is partially torn. If I get the prothane inserts will that still stop my wheel hop since the mount is torn? Or do I have to replace the mount than get the inserts? Im thinking I have to replace the mount first.
Old Jan 27, 2007 | 10:08 PM
ewetho's Avatar
ewetho
Default RE: torn motor mount?
Some have done it both ways depending on how solid you want it. You could just get race inserts and should be much better.
Old Jan 28, 2007 | 02:07 PM
blk94z28's Avatar
blk94z28
How bad are the vibrations from the race mounts? Does the dash vibrate at all,etc..? Did it completly eliminateyour wheel hop?
Old Jan 28, 2007 | 05:40 PM
ewetho's Avatar
ewetho
YES and NO
But not tha bad. Get it most letting the clutch our with little throttle and wheel gets better the stiffer you make it but that is why there are traction bar setups.
