help!!
Old Feb 18, 2007 | 04:26 AM
crappyneon's Avatar
crappyneon
Default help!!
I was driving home tonight and when I accelerated there was a huge cloud of white smoke that came out from behind me. When I came to the next stop, my car overheated and my boyfriend and I could both hear and feel boiling in the engine. When we got home, I checked under the hood. The last few weeks it's been shifting really weird, having problems excellerating, etc. I checked the oil for coolant (for head gasket problem...common with neons) and it was fine. But when I checked my transmission fluid, it was caked with a gel-like coolant. And, the resevoir for the coolant was leaking slightly as well. Any ideas on what this may be? Common problem? So far, I've heard it's either a crack in the engine block or possible a radiator? maybe a rear main seal?
Old Feb 18, 2007 | 09:32 PM
ewetho's Avatar
ewetho
Default RE: help!!
If your trans fluid and and radiator fluid are gooked up you probably blew the trans cooler in the radiator. Now you have a mess!!!
Old Feb 18, 2007 | 10:55 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: help!!
eww, look at the bright side, now you and your b/f have something to do next weekend
