cruise control install ...HELP....please
Old Feb 26, 2007 | 07:03 PM
boostdog's Avatar
boostdog
Default cruise control install ...HELP....please
Hello guys/gals I have an 02 that I added cruise control to but I cannot get the wiring figured out..if any of you have added cruise please give me some pointers. What pin or wires should I be using on the pcm. The install instructions are not helpful and the haynes manual does not tell me either. Please help me and any help is already appreciated! Thanks!
Old Feb 26, 2007 | 08:32 PM
spikeymikey87's Avatar
spikeymikey87
Default RE: cruise control install ...HELP....please
what wire from the pcm are you looking for and ill tell you the pin
Old Feb 27, 2007 | 01:01 AM
Pablodragon's Avatar
Pablodragon
is this a stock swap out?...or after market cruise?
is this another possible plug and play swap like swapping out the multi function switch?
..where the wiring and sensors are there and all you need is the multi-function switch/lever?
I have an SE and would love to add cruise...
