my check engine light codes
Old Mar 11, 2007 | 06:56 PM
gm830's Avatar
gm830
Default my check engine light codes
I just saw these codes on my car, can someone tell me what they mean?
P1684 Driver 5 Line 4
P0551 Power Steering Pressure Sensor Circuit Range/Performance
The last work I had done was last august and a power steering pump was replaced, could that mean there's a problem with that? I don't understand the other one at all. Help would be greatly appreciated =)
Old Mar 11, 2007 | 07:58 PM
neisg1's Avatar
neisg1
Default RE: my check engine light codes
P1684 Driver 5 Line 4 you show is a General Motors code.
The dodge code for P1684 is battery disconnected within the last 50 starts.
OBDII codes starting with P1*** are manufacturer specific and the listing in this forum is in error.
This is a pressure sensor mounted on the steering rack and I think is suppose to boost the idle if the pressure drops to low.
I would try resetting it and see if it comes back.
Old Mar 11, 2007 | 08:20 PM
gm830's Avatar
gm830
so the dodge code about the battery is nothing to worry about right? i haven't touched my battery so i don't know why that code would show
Old Apr 4, 2007 | 09:27 PM
gm830's Avatar
gm830
ok i unplugged the neg part of the battery about 11 days ago to reset the cel code and everything was fine until it came on yesterday as i was driving on the highway. it's the same 2 codes as before, can someone explain why these are coming back on or what i can do to fix them?
Old Apr 5, 2007 | 10:45 PM
gm830's Avatar
gm830
c'mon, one of you 196 people viewing this has to know an answer for me :-(
Old Apr 5, 2007 | 11:00 PM
01neon01's Avatar
01neon01
how long did you leave it unplugged for?
Old Apr 5, 2007 | 11:22 PM
gm830's Avatar
gm830
like 5mins. the check engine light stayed off for a little over a week
Old Apr 5, 2007 | 11:32 PM
neisg1's Avatar
neisg1
One possibility is that the Power Steering Pressure Sensor on the rack is defective and allowing the idle to drop too low. This could result in the engine stumbling causing the alternator voltage to drop triggering the P1684 is battery disconnected code.
Old Apr 6, 2007 | 12:33 AM
01neon01's Avatar
01neon01
just leave it disconnected for at least 10 minutes. then re check what codes you get. if you get the 1684 dont worry about it it will stay there until you have 50 starts on the computer again.
Old Apr 6, 2007 | 12:35 AM
gm830's Avatar
gm830
so is the power steering thing something i should be worried about? i had a new power steering pump put in last august so i dunno if it has anything to do with that
