Wheel Bearing help
Old Mar 11, 2007 | 11:00 PM
thomaskollars's Avatar
thomaskollars
Default Wheel Bearing help
Could someone do me a favor and give me a step by step guide to changing out my passanger side wheel bearing? Would be a great help (2005 SXT)
Old Mar 12, 2007 | 05:17 PM
contagious19's Avatar
contagious19
Default RE: Wheel Bearing help
do u think it would b da same as a 2000 dodge neon? if it is ill tell u now ur going to need a hard press to get it out og its housing. Lets c take off the wheel. disomount da caliper and take off da rotor. disconnect da shock absorber.
Old Mar 12, 2007 | 05:41 PM
03neonRT's Avatar
03neonRT
Yes, it would be the same as a 2000 Neon. Our wheel bearings are press fit, which means, if you dont have a hydraulic press it will be very difficult to remove the old bearing and press the new one into the housing...not neccessarily impossible, but quite difficult.
Old Mar 12, 2007 | 06:23 PM
contagious19
remove da CVC from da back and remove da whole housing and u need a press to take da old one out and put a new one in.
Old Mar 12, 2007 | 07:21 PM
contagious19
its easy i did it wit da help of my dad and it was our first time doing it and it was easy.
