No Fuel Level Bus Message? Any Clue?
Old Mar 19, 2007 | 05:23 PM
smallcar's Avatar
smallcar
Default No Fuel Level Bus Message? Any Clue?
Hey all, I was hoping somebody might have a clue as to what a U110C trouble code "No Fuel Level Bus Message" might really mean. I first noticed this after the instrument cluster went completely dead, that non of the gauges worked. The fuel gauge read empty even though there was a 1/2 tank of gas. The need fuel warning buzzer was going off and the engine trouble light was on.
After a little research I decide to pull the battery cables and clean the connections. This worked for a day or so, everything seemed OK. But then the instrument panel went dead again, however at this time no trouble lights.
The car starts up fine, seem to run fine, but no instrument panel.
What can this all mean? any clue?
Thanks for you help!
RCP
Old Oct 13, 2007 | 12:28 PM
Great White Wing's Avatar
Great White Wing
Default RE: No Fuel Level Bus Message? Any Clue?
I was wondering if you found anything to fix with the U110C NO FUEL LEVEL BUS MESSAGE?
John
