New Head
Old Mar 22, 2007 | 11:22 PM
Potato_112's Avatar
Potato_112
Default New Head
Would like to know how hard is it to replace the head on a 2000 Plymouth MTX. The Sis striped her threads that house the spark plugs. Thanks!
Old Mar 23, 2007 | 03:11 AM
NHARINTON's Avatar
NHARINTON
Default RE: New Head
not that hard... what year is it?
Old Mar 23, 2007 | 04:24 AM
Potato_112's Avatar
Potato_112
Its a 2000 with a 5-speed...Im guessing it would be an easy swap right with another if you replace the seals
Old Mar 23, 2007 | 06:01 AM
NHARINTON's Avatar
NHARINTON
yeah not that bad at all...... sould be 3-4 hrs max if you know what you are doing!
Old Mar 23, 2007 | 03:49 PM
Potato_112's Avatar
Potato_112
Alright. This would be my first time pulling a head off a car engine. You basically remove the exhaust and intake and timing belt right?
Old Mar 23, 2007 | 04:45 PM
tooslow's Avatar
tooslow
if you plan on swapping the valve train componnent over it might be pain because the valve springs on soch don't go on with out a fight. you just be sure too line up all your marks and you can do it in one weekend no problem also you might want too replace the water timing belt ant tensenior while in there
Old Mar 23, 2007 | 06:05 PM
Freerider's Avatar
Freerider
replacing the head is no easy simple task....
I took mine off to do my camshaft and to get at the header easier...
You need to pretty much take apart the whole engine bay.
It can be done in a weekend if you know how it is done and if you have help to do it.
