05 dodge neon trans lines leaking...
Old Mar 24, 2007 | 02:20 AM
Jeffmarble's Avatar
Jeffmarble
Default 05 dodge neon trans lines leaking...
has anyone ever replaced the trans lines looks like pressed fittings going into radiator left side is leaking. also does both sides come with the rubber grommet i noticed the right side has a grommet around it. also left side fan when is it supposed to kick on noticed it never turned on right side only turns on at higher temps.
