Diagnostic Trouble Code List
Old Mar 10, 2009 | 08:55 PM
Pyro's Avatar
Pyro
I Beat Tetris
P0900 - P0999
P0900 Clutch Actuator Circ/Open
P0901 Clutch Actuator Circ Range/Perf
P0902 Clutch Actuator Circ Low
P0903 Clutch Actuator Circ Hi
P0904 Gate Select Pos Circ
P0905 Gate Select Pos Circ Range/Perf
P0906 Gate Select Pos Circ Low
P0907 Gate Select Pos Circ Hi
P0908 Gate Select Pos Circ Interm
P0909 Gate Select Ctrl Error
P0910 Gate Select Actuator Circ/Open
P0911 Gate Select Actuator Circ Range/Perf
P0912 Gate Select Actuator Circ Low
P0913 Gate Select Actuator Circ Hi
P0914 Gear Shift Pos Circ
P0915 Gear Shift Pos Circ Range/Perf
P0916 Gear Shift Pos Circ Low
P0917 Gear Shift Pos Circ Hi
P0918 Gear Shift Pos Circ Interm
P0919 Gear Shift Pos Ctrl Error
P0920 Gear Shift Forward Actuator Circ/Open
P0921 Gear Shift Forward Actuator Circ Range/Perf
P0922 Gear Shift Forward Actuator Circ Low
P0923 Gear Shift Forward Actuator Circ Hi
P0924 Gear Shift Reverse Actuator Circ/Open
P0925 Gear Shift Reverse Actuator Circ Range/Perf
P0926 Gear Shift Reverse Actuator Circ Low
P0927 Gear Shift Reverse Actuator Circ Hi
P0928 Gear Shift Lock Solenoid Ctrl Circ/Open
P0929 Gear Shift Lock Solenoid Ctrl Circ Range/Perf
P0930 Gear Shift Lock Solenoid Ctrl Circ Low
P0931 Gear Shift Lock Solenoid Ctrl Circ Hi
P0932 Hydraulic Press Sens Circ
P0933 Hydraulic Press Sens Range/Perf
P0934 Hydraulic Press Sens Circ Low
P0935 Hydraulic Press Sens Circ Hi
P0936 Hydraulic Press Sens Circ Interm
P0937 Hydraulic Oil Temp Sens Circ
P0938 Hydraulic Oil Temp Sens Range/Perf
P0939 Hydraulic Oil Temp Sens Circ Low
P0940 Hydraulic Oil Temp Sens Circ Hi
P0941 Hydraulic Oil Temp Sens Circ Interm
P0942 Hydraulic Press Unit
P0943 Hydraulic Press Unit Cycling Period Too Short
P0944 Hydraulic Press Unit Loss of Press
P0945 Hydraulic Pump Relay Circ/Open
P0946 Hydraulic Pump Relay Circ Range/Perf
P0947 Hydraulic Pump Relay Circ Low
P0948 Hydraulic Pump Relay Circ Hi
P0949 Auto Shift Manual Adaptive Learning Not Complete
P0950 Auto Shift Manual Ctrl Circ
P0951 Auto Shift Manual Ctrl Circ Range/Perf
P0952 Auto Shift Manual Ctrl Circ Low
P0953 Auto Shift Manual Ctrl Circ Hi
P0954 Auto Shift Manual Ctrl Circ Interm
P0955 Auto Shift Manual Mode Circ
P0956 Auto Shift Manual Mode Circ Range/Perf
P0957 Auto Shift Manual Mode Circ Low
P0958 Auto Shift Manual Mode Circ Hi
P0959 Auto Shift Manual Mode Circ Interm
P0960 Press Ctrl Solenoid A Ctrl Circ/Open
P0961 Press Ctrl Solenoid A Ctrl Circ Range/Perf
P0962 Press Ctrl Solenoid A Ctrl Circ Low
P0963 Press Ctrl Solenoid A Ctrl Circ Hi
P0964 Press Ctrl Solenoid B Ctrl Circ/Open
P0965 Press Ctrl Solenoid B Ctrl Circ Range/Perf
P0966 Press Ctrl Solenoid B Ctrl Circ Low
P0967 Press Ctrl Solenoid B Ctrl Circ Hi
P0968 Press Ctrl Solenoid C Ctrl Circ/Open
P0969 Press Ctrl Solenoid C Ctrl Circ Range/Perf
P0970 Press Ctrl Solenoid C Ctrl Circ Low
P0971 Press Ctrl Solenoid C Ctrl Circ Hi
P0972 Shift Solenoid A Ctrl Circ Range/Perf
P0973 Shift Solenoid A Ctrl Circ Low
P0974 Shift Solenoid A Ctrl Circ Hi
P0975 Shift Solenoid B Ctrl Circ Range/Perf
P0976 Shift Solenoid B Ctrl Circ Low
P0977 Shift Solenoid B Ctrl Circ Hi
P0978 Shift Solenoid C Ctrl Circ Range/Perf
P0979 Shift Solenoid C Ctrl Circ Low
P0980 Shift Solenoid C Ctrl Circ Hi
P0981 Shift Solenoid D Ctrl Circ Range/Perf
P0982 Shift Solenoid D Ctrl Circ Low
P0983 Shift Solenoid D Ctrl Circ Hi
P0984 Shift Solenoid E Ctrl Circ Range/Perf
P0985 Shift Solenoid E Ctrl Circ Low
P0986 Shift Solenoid E Ctrl Circ Hi
P0987 Trans Fluid Press Sens/Switch E Circ
P0988 Trans Fluid Press Sens/Switch E Circ Range/Perf
P0989 Trans Fluid Press Sens/Switch E Circ Low
P0990 Trans Fluid Press Sens/Switch E Circ Hi
P0991 Trans Fluid Press Sens/Switch E Circ Interm
P0992 Trans Fluid Press Sens/Switch F Circ
P0993 Trans Fluid Press Sens/Switch F Circ Range/Perf
P0994 Trans Fluid Press Sens/Switch F Circ Low
P0995 Trans Fluid Press Sens/Switch F Circ Hi
P0996 Trans Fluid Press Sens/Switch F Circ Interm
P0997 Shift Solenoid F Ctrl Circ Range/Perf
P0998 Shift Solenoid F Ctrl Circ Low
P0999 Shift Solenoid F Ctrl Circ Hi
Old Mar 10, 2009 | 08:56 PM
Pyro's Avatar
Pyro
I Beat Tetris
P0A00 - P0A29
P0A00 Motor Electronics Coolant Temp Sens Circ
P0A01 Motor Electronics Coolant Temp Sens Circ Range/Perf
P0A02 Motor Electronics Coolant Temp Sens Circ Low
P0A03 Motor Electronics Coolant Temp Sens Circ Hi
P0A04 Motor Electronics Coolant Temp Sens Circ Interm
P0A05 Motor Electronics Coolant Pump Ctrl Circ/Open
P0A06 Motor Electronics Coolant Pump Ctrl Circ Low
P0A07 Motor Electronics Coolant Pump Ctrl Circ Hi
P0A08 DC/DC Conv Status Circ
P0A09 DC/DC Conv Status Circ Low Input
P0A10 DC/DC Conv Status Circ Hi Input
P0A11 DC/DC Conv Enable Circ/Open
P0A12 DC/DC Conv Enable Circ Low
P0A13 DC/DC Conv Enable Circ Hi
P0A14 Engine Mount Ctrl Circ/Open
P0A15 Engine Mount Ctrl Circ Low
P0A16 Engine Mount Ctrl Circ Hi
P0A17 Motor Torque Sens Circ
P0A18 Motor Torque Sens Circ Range/Perf
P0A19 Motor Torque Sens Circ Low
P0A20 Motor Torque Sens Circ Hi
P0A21 Motor Torque Sens Circ Interm
P0A22 Generator Torque Sens Circ
P0A23 Generator Torque Sens Circ Range/Perf
P0A24 Generator Torque Sens Circ Low
P0A25 Generator Torque Sens Circ Hi
P0A26 Generator Torque Sens Circ Interm
P0A27 Battery Power Off Circ
P0A28 Battery Power Off Circ Low
P0A29 Battery Power Off Circ Hi
Old Mar 10, 2009 | 08:57 PM
Pyro's Avatar
Pyro
I Beat Tetris
P1000 - P1099
P1000 Ignition Circ Low
P1001 Ignition Circ Hi
P1004 ECU Battery Feed & Power Grounds
P1005 Sys Ground Circ
P1006 EGR/EVAP Solenoid Circ Low
P1007 EGR/EVAP Solenoid Circ Hi
P1008 Power Steering Circ Low
P1009 Power Steering Circ Hi
P1012 MPA Circ Low
P1013 MPA Circ Hi
P1014 Fuel Pump Circ Low
P1015 Fuel Pump Circ Hi
P1016 Charge Air Temp Circ Low
P1017 Charge Air Temp Circ Hi
P1018 Serial Data Circ
P1019 Power Latch Not Set
P1021 Engine Failed To Start Due To Mechanical, Fuel or Ignition Conditions
P1022 Starter Relay Circ Low
P1024 ECU Start Circ Low
P1025 WOT Circ Low
P1026 WOT Circ Hi
P1027 ECU Sees Wide Open Throttle
P1028 ECU Does Not See Wide Open Throttle
P1029 ISA Closed Throttle Circ Low
P1030 ISA Closed Throttle Circ Hi
P1031 ECU Sees Closed Throttle
P1032 ECU Does Not See Closed Throttle
P1033 ISA Circs
P1037 TP Sens Circ Reads Low
P1038 Park/Neutral Line Hi
P1039 Park/Neutral Line Low
P1040 Latched B+ Line Low
P1041 Latched B+ Line Hi
P1042 No Latched B+ 1/2 Volt Drop
P1043 Shift Lamp Circ Grounded
P1044 D2–1 Circ Low (A/T) or
P1044 Upshift Lamp Circ (M/T) or
P1044 Shift Lamp Circ Hi
P1045 Shift Lamp Circ Open
P1047 Wrong ECU
P1048 M/T Vehicle Configuration
P1049 A/T Vehicle Configuration
P1050 Idle RPM Low
P1051 Idle RPM Hi
P1052 MAP Sens Out Of Limits
P1053 Change In MAP Reading Out Of Limits
P1054 Coolant Sens & 5V Supply for TP Sens/MAP Circs Low
P1055 Coolant Sens Circ Hi
P1056 Inactive Coolant Temp Sens
P1059 A/C Request Circ Low
P1060 A/C Request Circ Hi
P1061 A/C Select Circ Low
P1062 A/C Select Circ Hi
P1063 A/C Clutch Circ Low
P1064 A/C Clutch Circ Hi & Power Steering Input
P1068 Latch Relay Circ Hi
P1069 No Tach
P1074 ECU Does Not See Speed Sens
Old Mar 10, 2009 | 08:58 PM
Pyro's Avatar
Pyro
I Beat Tetris
P1100 - P1199
P1106 MAP Sens Circ Interm Hi Voltage
P1107 MAP Sens Circ Interm Low Voltage
P1110 Decreased Engine Perf Due To Hi Intake Air Temp
P1111 IAT Sens Circ Interm Hi Voltage
P1112 IAT Sens Circ Interm Low Voltage
P1114 ECT Sens Circ Interm Low Voltage
P1115 ECT Sens Circ Interm Hi Voltage
P1121 TPS Circ Interm Hi Voltage
P1122 TPS Circ Interm Low Voltage
P1125 Accelerator Pedal Pos Sys
P1133 HO2S Insufficient Switching Bank1 Sens1
P1134 HO2S Insufficient Transition Time Ratio Bank1 Sens1
P1153 HO2S Insufficient Switching Bank2 Sens1
P1154 HO2S Insufficient Transition Time Ratio Bank2 Sens1
P1180 Decreased Engine Perf Due To Hi Inj Pump Fuel Temp
P1191 Intake Air Duct Leak
P1192 Inlet Air Temp Sens Voltage Low
P1193 Inlet Air Temp Voltage Hi
P1194 02 Heater Perf
P1195 1/1 02 Sens Slow During Catalyst Monitor
P1196 2/1 02 Sens Slow During Catalyst Monitor
P1197 1/2 02 Sens Slow During Catalyst Monitor
P1198 Radiator Temp Sens Volts Too Hi
P1199 Radiator Temp Sens Volts Too Low
Old Mar 10, 2009 | 08:59 PM
Pyro's Avatar
Pyro
I Beat Tetris
P1200 - P1299
P1214 Inj Pump Timing Offset
P1216 Fuel Solenoid Response Time Too Short
P1217 Fuel Solenoid Response Time Too Long
P1218 Inj Pump Calibration Circ
P1271 Accelerator Pedal Pos Sens1-2 Correlation
P1272 Accelerator Pedal Pos Sens2-3 Correlation
P1273 Accelerator Pedal Pos Sens1-3 Correlation
P1275 Accelerator Pedal Pos Sens1 Circ
P1277 Accelerator Pedal Pos Sens1 Low Voltage
P1278 Accelerator Pedal Pos Sens1 Hi Voltage
P1280 Accelerator Pedal Pos Sens2 Circ
P1281 Engine is Cold Too Long
P1282 Accelerator Pedal Pos Sens2 Low Voltage
P1282 Fuel Pump Relay Ctrl Circ or
P1283 Accelerator Pedal Pos Sens2 Hi Voltage
P1283 Idle Select Signal Invalid or
P1284 Fuel Inj Pump Battery Voltage Out Of Range
P1285 Accelerator Pedal Pos Sens3 Circ
P1285 Fuel Inj Pump Ctrller Always On or
P1286 Accelerator Pos Sens Supply Voltage Too Hi
P1287 Accelerator Pedal Pos Sens3 Low Voltage
P1287 Fuel Inj Pump Ctrl Supply Voltage Low or
P1288 Accelerator Pedal Pos Sens3 Hi Voltage
P1288 Intake Manif Short Runner Solenoid Circ or
P1289 Manif Tune Valve Solenoid Circ
P1290 CNG Fuel Sys Press Too Hi
P1291 No Temp Rise Seen From Intake Heaters
P1292 CNG Press Sens Voltage Too Hi
P1293 CNG Press Sens Voltage Too Low
P1294 Target Idle Not Reached
P1295 No 5Vs to Throttle Pos Sens
P1296 No 5Vs to MAP Sens
P1297 No Change in MAP from Start To Run
P1298 Lean Operation at Wide Open Throttle
P1299 Vacuum Leak Found (IAC Fully Seated)
Old Mar 10, 2009 | 09:01 PM
Pyro's Avatar
Pyro
I Beat Tetris
P1300 - P1399
P1336 Crank Pos Sys Variation Not Learned
P1345 Crank Pos/Camshaft Pos Correlation
P1351 Ignition Ctrl Circ Hi Voltage
P1361 Ignition Ctrl Circ Low Voltage
P1380 Electronic Brake Ctrl Rough Road Data Unusable
P1381 Misfire Detected-No Electronic Brake Ctrl Data
P1388 Auto Shutdown Relay Ctrl Circ
P1389 No ASD Relay Output Voltage at PCM
P1390 Timing Belt Skipped 1 Tooth or More
P1391 Interm Loss of CMP or CKP
P1398 Misfire Adaptive Numerator at Limit
P1399 Wait to Start Lamp Circ
Old Mar 10, 2009 | 09:02 PM
Pyro's Avatar
Pyro
I Beat Tetris
P1400 - P1499
P1403 No 5Vs to EGR Sens
P1404 EGR Valve Closed Pintle Pos
P1406 EGR Valve Pos
P1409 EGR Valve Sys leak
P1415 AIR Sys Bank1
P1416 AIR Sys Bank1
P1441 Evap Emissions Flow During Non-Purge
P1475 Auxiliary 5V Supply Voltage Hi
P1476 Too Little Sec Air
P1477 Too Much Sec Air
P1478 Battery Temp Sens Volts Out of Limit
P1479 Trans Fan Relay Circ
P1480 PCV Solenoid Circ
P1481 EATX Misfire RPM Signal out of Range
P1482 Catalyst Temp Sens Circ Shorted Low
P1483 Catalyst Temp Sens Circ Shorted Hi
P1484 Catalytic Conv Overheat Detected
P1485 Air Inj Solenoid Circ
P1486 Eva Leak Monitor Pinched Hose Found
P1487 Hi Speed Radiator Fan CTRL Relay Circ
P1488 Auxiliary 5V Supply Output Too Low
P1489 Hi Speed Fan CTRL Relay Circ
P1490 Low Speed Fan CTRL Relay Circ
P1491 Radiator Fan Ctrl Relay Circ
P1492 Ambient/Battery Temp Sens Volts Too Hi
P1493 Ambient/Battery Temp Sens Volts Too Low
P1494 Leak Detection Pump Switch or Mechanical Fault
P1495 Leak Detection Pump Solenoid Circ
P1496 5V Supply, Output Too Low
P1498 Hi Speed Radiator Fan Ground CTRL Relay Circ
Old Mar 10, 2009 | 09:03 PM
Pyro's Avatar
Pyro
I Beat Tetris
P1500 - P1599
P1508 IAC Sys Low RPM
P1509 IAC Sys Hi RPM
P1594 Charging Sys Voltage Too Hi
P1595 Speed Ctrl Solenoid Circs
P1596 Speed Ctrl Switch Always Hi
P1597 Speed Ctrl Switch Always Low
P1598 A/C Press Sens Volts Too Hi
P1599 A/C Press Sens Volts Too Low
Old Mar 10, 2009 | 09:04 PM
Pyro's Avatar
Pyro
I Beat Tetris
P1600 - P1699
P1602 PCM Not Programmed
P1621 PCM Memory Perf or Write
P1626 Vehicle Theft Sys Ctrl Loss of Data
P1627 A/D Perf
P1630 Vehicle Theft Sys PCM in Learn Mode
P1631 Vehicle Theft Sys Improper Password
P1635 5V Ref ( Circ
P1639 5V Ref ( Circ
P1641 MIL Ctrl Circ
P1643 Wait To Start Lamp Ctrl Circ
P1646 5V Ref (C) Circ
P1652 J1850 Comms Bus
P1653 EGR Vent Solenoid Ctrl Circ
P1654 Service Throttle Soon Lamp Ctrl Circ
P1655 EGR Solenoid Ctrl Circ
P1656 Wastegate Solenoid Ctrl Circ
P1680 Clutch Released Switch Circ
P1681 No I/P Cluster CCD/J1850 Messages Received
P1682 Charging Sys Voltage Too Low
P1683 Speed Ctrl Power Relay; or S/C 12v Driver CKT
P1684 Battery Disconnected in the last 50 Starts
P1685 Skim Invalid Key
P1686 No SKIM BUS Messages Received
P1687 No Cluster BUS Message
P1688 Internal Fuel Inj Pump Ctrller Failure
P1689 No Comm between ECM & Inj Pump Mod
P1690 CKP Sens Does Not Agree with ECM CKP Sens
P1691 Fuel Sys ESS RPM Error
P1692 DTC Set In ECM
P1693 DTC Detected in Companion JTEC Mod
P1694 No BUS Message Received from ECM Mod
P1695 No CCD/J1850 Messages from the Body Ctrl Mod.
P1696 PCM Failure EEPROM Write Denied
P1697 PCM Failure SRI Mile Not Stored
P1698 No CCD/J1850 Message From TCM/PCM
Old Mar 10, 2009 | 09:06 PM
Pyro's Avatar
Pyro
I Beat Tetris
P1700 - P1799
P1719 Skip Shift Solenoid Circ
P1740 TCC or O/D Solenoid Perf
P1756 Gov Press Not Equal to Target @ not15-20 PSI
P1757 Gov Press above 3 PSI in gear with 0 MPH
P1762 Gov Press Sens Offset Volts Too Low or Hi
P1763 Governor Press Sens Volts Too Hi
P1764 Governor Press Sens Volts Too Low
P1765 Trans 12 Volt Supply Relay CTRL Circ
P1800 - P1899
P1899 P/N Switch Stuck in Park or in Gear
