View Poll Results: What kind of headers are you running?
Edlebrock
12.70%
Summit
6.35%
Pacesetters
44.44%
Hooker
3.17%
Other (Post it)
33.33%
Voters: 63. You may not vote on this poll
Headers
Old Mar 1, 2013 | 08:18 AM
  #31
AtomicDog's Avatar
AtomicDog
I had the same fit issue with my Pacesetter shorties. What I end up doing to get the Y-pipe lined up to bolt-up it to the shorty header on one side is to use my Port-A-Power hydraulic spreader to push the pipe into position to get the bolts to line up. I wedge the spreader between the frame and the y-pipe just under the header outlet and pump up the hydraulic pump to get the spreader to move the pipe. To see the tool I'm referencing to help with the visual, see the attached Harbor Freight link for the tool I used:
http://www.harborfreight.com/4-ton-h...kit-44899.html
Worked for me perfectly..
Old May 1, 2013 | 05:10 PM
  #32
zman17's Avatar
zman17
Retired Moderator - RIP
Stock...........
Old Oct 16, 2013 | 07:03 AM
  #33
ChillyPhil's Avatar
ChillyPhil
Dumb eBay stainless ones cracked at a weld on the driver side..
How hard are them pacesetter longtubes to put on with my high flow cat?
Old Oct 16, 2013 | 04:41 PM
  #34
clipper77's Avatar
clipper77
Ebay!
So far, so good...
Old Oct 16, 2013 | 07:11 PM
  #35
Spillage's Avatar
Spillage
Pacesetter LT's (3" collectors) require a new Y-pipe (they offer one) that crosses behind the transmission, meaning the Cat has to be moved back a couple of feet.
If you're talking about an OE style Cat (2I/1O), then no... you'll need a 3" SI/SI Cat... and a new bung, and extention cable for the rear O2 sensor.
The right side is easy enough to install, but the left side needs the starter dropping to get it in.
Old Nov 13, 2013 | 10:49 PM
  #36
lastrights's Avatar
lastrights
Default hey shorty
Originally Posted by talon6
edel ceramic shorties,stage 8 fasteners and remflex gaskets. a nice little improvement over stock.
I had longtubes on my ram , but I have a Durango with the 5.9 I just want shortys , where did you buy them and what size bolts did you go with. is it even worth to to the swap ? was there any problems with bolts hitting any headers ?
Old Nov 18, 2013 | 10:53 PM
  #37
redneck_ram's Avatar
redneck_ram
not true... ive done it twice without having to remove the starter.
Old Nov 18, 2013 | 11:32 PM
  #38
Spillage's Avatar
Spillage
I'm about to find out this week
PS; I was going by the instructions.
Old Nov 26, 2013 | 08:17 PM
  #39
Spillage's Avatar
Spillage
Not only did the starter have to come off, but the engine mount unbolted so it could be jacked up a couple of inches, to get the driver-side in...
Installed, there is very little clearance to the frame rail on the driver-side... lucky the motor torques to other direction, so there isn't a hit.
To all that said I would like my LT's and Magnaflow exhaust... you were correct... louder, but not overly loud, and a beautiful clean deep V8 rumble.
Old Nov 26, 2013 | 08:26 PM
  #40
redneck_ram
strange... as stated before, never had to remove mine at all.
im going to be losing my longtubes for a set of shorties, and the jegs y-pipe. i need more clearance for the front driveshaft.
