The Official 2nd Gen RAM Forum OT thread
Old Jul 9, 2013 | 04:22 PM
  #10441
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
lol
You missed the point. Purple smoke. Purple is one of the colors commonly associated with gays. lol
Old Jul 9, 2013 | 04:24 PM
  #10442
merc225hp's Avatar
merc225hp
Originally Posted by beginningjockey
Proves that Ford IDIs can produce more smoke than Cummins? yes I knew that already...
Who cares, that S*** should be illegal truck impounded and opt fined up the rear end for polluting.
Old Jul 9, 2013 | 04:33 PM
  #10443
dodge dude94
I seafoamed my Ram, so does that mean my truck should be impounded and I be fined up the *** for it?
It's not government's duty to do that ****. Come on.
Old Jul 9, 2013 | 04:41 PM
  #10444
aofarrell2's Avatar
aofarrell2
lol
O **** lol! So purple fireworks are gay to, huh?
Most people never do that on a regular basis...
DD is right.. The government has their nose in too much stuff already, either their nose needs to be cut off or they need to pull it out. It's a proven fact, emissions controls do NOT lower the amount of emissions! Its undeniable that emissions stuff causes engines to use more fuel, and strain to make rated power. So if you get rid of emissions cr@p, then people will use less fuel =less exhaust, more power=the engine doesn't have to run as hard, which once again means less exhaust. I'm fine with certain emissions controls, such as fuel tank vapour purge, crankcase ventilation, and air injection (injecting air into the hot exhaust causes CO and NOx to be formed into H2O and CO2, with a proper exhaust setup it won't restrict exhaust at all). Properly designed they will have absolutely no negative effect on the engine and reduce CO and other obviously bad gases...
Old Jul 9, 2013 | 04:44 PM
  #10445
Jigabop's Avatar
Jigabop
I try not to produce extra smoke, but sometimes it just can't be helped...
I was in 4th gear and one of the passengers wanted me to do a burnout infront of his parents house (seen in the left of the picture) so I held the brake down which bogged down the motor and floored the skinny pedal...
truck went...smoke....twins spooled, very light smoke and both 35" mud tires screaming.
the thing does haze all of the time though...
this is the idle haze on a cold motor:
when the engine is warm it lightens up to a barely visible haze.
and I don't wanna hear it about pollution. that truck blowing black coal year round for 10 years produces less pollution than the manufacturing process of a single Toyota prius...
diesel exhaust like that settles to the ground as dust and blows away. does no more pollution than a small camp fire or bar-b-que or chimley...
now in that ford pic...just sitting in one spot blowing smoke just to blow smoke? and coloring it? gives the rest of us a bad name...
Old Jul 9, 2013 | 04:47 PM
  #10446
aofarrell2's Avatar
aofarrell2
Diesel exhaust that is black is mostly carbon, which is ACTUALLY HELPFUL to the environment.
I do have to agree with Jig that coloring exhaust was pretty dumb...
  #10447
dodge dude94
Purple fireworks can't help but be gay. But if you're going to make your truck smoke, purple is not the color for it. Makes it look like cheech and chong went wild. lol
Nice write up on government regulation! I like cats, cats are good. Keeps my eyes from burning. lol
Old Jul 9, 2013 | 05:36 PM
  #10448
aofarrell2's Avatar
aofarrell2
Cats, well, if the engine is properly tuned, they aren't even needed. There's a member here on DF, who sucessfully passed California emissions with a gutted cat and a performance SCT tune...
Half the problem is that factory cats aren't big enough.
Old Jul 9, 2013 | 05:43 PM
  #10449
stewie01's Avatar
stewie01
Is there supposed to be a "clicking" sound on a front wheel drive CV Axle vehicle?
When I rotate the passenger front tire on the wifes car, I'm talkin a tiny amount, maybe an 1" forward and backwards, there's a clicking noise.
It gets much louder with more force behind the tire rotation...
Didn't find anything on the driver rear besides a completly torn up shock boot. Everything else is nice and tight...
Old Jul 9, 2013 | 05:44 PM
  #10450
aofarrell2's Avatar
aofarrell2
Put your hand on the CV shaft, if it wiggles up and down, time to replace it...
