got boost?
just getting my camera figured out and snapped this, its a part throttle run in 4th gear, the top gauge is the big turbo boost gauge (0-35 psi) the middle one is small turbo/manifold boost (0-100 psi) the bottom one is egt, the one to the left is exhaust manifold pressure, but its plugged at the moment, and fuel pressure on the coloum, it hits around 50 psi total, and around 30 psi on the big turbo, it will do a lot more, but not with a camera in my hand and driving a manual, it can get wild if the tires break loose at 65 mph
sorry for the s**ty quality
http://www.youtube.com/watch?v=uyF-8Y4iEMc
its all built by me from scratch, the top turbo is a switzer S300 base with 62mm comp wheel, 68mm turbine wheel, 13cm housing that i fully ported, and fully modified internal wastegate, along with a 38mm external wastegate, big turbo is a 75mm S400,
