Plenum and CB pics
last week I did some work on my truck
Aluminum plate
timing chain
cap/rotor/wires/plugs
water pump
bypass hose
pcv valve
thermostat
While I was working on it I took some pics, figured I would throw them up since everybody likes pics
What the old gasket looked like, not bad at all for 178k
After pulling intake, valve covers and water pump. Taking a break for a beer and getting setup for pulling the t-chain cover
Back in cleaning up the gasket surfaces
Plenum plate ready to go in after a quick acetone fix and some scuffing of the gasket suface
Plate installed and all torqued down, added some red loctite so the bolts dont think about coming loose(my ebay plate fit great and was much cheaper than hughes)
Stuff coming back together, I didnt take much time cleaning parts because you cant see half the stuff when put back together....I did take the time to paint the valve covers flat black
Quick work on the tb to try and get some more flow, and seems to work well
Then this week I decided that working on the truck the last week wasnt enough and decided to install a cb radio and antennas, originally a cheap cobra 19 or something like that was installed then I got a cobra 29 from a friend so I installed it
Mounted under the center seat not in the way of passengers feet and unnoticeable from the outside, yet easy to reach while driving
Front and rear view of the antennas mounted with springs
Also added a PA which might get me into trouble on of these days
I think Im done working on the truck for a week or so.
Aluminum plate
timing chain
water pump
bypass hose
pcv valve
thermostat
nice man , what wires do you have on there ? im doing a tune up and i dont think imma go with msd this time around going to go with what napa or advance has if its more than 8.0 mm
also how was the slop on the chain ? hows the throttle responce
much of a diffrence ?
There 8mm wires from summit, they sell a tune up kit for our trucks so I got that
Slop on the chain was not to bad but worth changing, noticed a little bit of a difference in power after it was all said and done
Idles so nice after the new wires and stuff
Been driving it since and no leaks and everything works right, so I must be halfway decent at this working on my own sh^t thing
Great Job man! did the essentials and got it done. Check and Check. Hows the beast running now? Yeah looked like you scuffed up the heck outta that TB hope you didnt do the bottom like that and if you did hope you added some sealant. :P Looks good though man, but proof is in the pudding. whatever that means :P
Trending Topics
I did go a little deep in a couple spots but I have no leaks, didnt touch the bottom(except with a stone to make sure it was straight), not much to mess with there,
If your just doing the plenum fix you can get it done after work one day and let it sit for the next and be good to go.
Going to find all my reciepts and post up the final price with all the little odds and ends.
