Will these fit????
Old Oct 28, 2011 | 08:09 AM
mackbarr1014's Avatar
mackbarr1014
Default Will these fit????
Hey can I fit 32x11x50 on 15 inch rims with out a leveling kit?
Old Oct 28, 2011 | 08:55 AM
8uzzsaw's Avatar
8uzzsaw
I had my 285/75/16's (32.8)on my truck before my lift. They fit in the wheel well but they rubbed on the lower control arm. Lift wont fix that rub though, only backspaced rims or some wheel spacers get rid of that.
Edit: Rubbing was at full turn.
Old Nov 1, 2011 | 06:26 PM
DodgeItRamIt97's Avatar
DodgeItRamIt97
Yea that would be a tight fit. Id say the chances are pretty good theyd fit fine with a small lift or level. the problem is when you turn the tires all the moving parts behind it that rub, so like the last guy said lifting wont solve some problems.
Old Nov 1, 2011 | 07:09 PM
BackwoodsRam's Avatar
BackwoodsRam
outting on wheel spacers add a lot of stress to the front hub bearings, and those things arent exactly stout to begin with
Old Nov 14, 2011 | 09:07 PM
EvanBoothe123's Avatar
EvanBoothe123
When I first got my 1997 Ram 1500 Bone stock I put 33x12.50x15's on it and they rubbed a bit in front on full turns, so my answer would be a big yes.
Old Nov 14, 2011 | 09:08 PM
EvanBoothe123
let me re phrase that, before I put the 33's on I had 31's and they did not rub at all. I don't see why 32's wouldn't be fine. I would say do it.
