Curious about rpm
Old Nov 25, 2011 | 11:06 AM
8uzzsaw's Avatar
8uzzsaw
That does sound quite high. At 110 km/h I'm at about 1750 Rpm with 3.55 and 285/75/16's. Rpm's are lower because of my larger tire size, but still, you should be getting better than that by a long shot. Either your OD isnt engaging or maybe your tach is off like SilverSS suggested.
Are you pulling anything or carrying a lot of weight in the truck?
Old Nov 25, 2011 | 11:30 AM
dodgeman2289's Avatar
dodgeman2289
ya im at 1900rpm at 70 3.55 265/70/17.. i just got my shift kit installed turned out i had a broken o/d spring but when it broke it still worked right. but the guy said that my o/d would of went out eventually
Old Nov 25, 2011 | 03:56 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by gdstock
Without anything needing to be done on my Ram today other than vacuum carpet from dirt and little pieces of plastic after replacing dash, and checking the oil, I tend to over think things.
Two weeks ago, took the Ram on a 1000 mile trip to Houston and back. Got about 11mpg. Truck ran good, but darn, can't afford that! Yota gets 17! I noticed that at 70 mph in OD, rpm is about 3200. Is this normal? Seems pretty high to me.
Wow, 3200? Something is wrong. My 2500 with 4:10's at 80 mph with 265's barely get's to 2500 rpm.
Old Nov 25, 2011 | 08:41 PM
gdstock's Avatar
gdstock
That would explain the crappy gas mileage......Now, I wonder what could cause this? Any ideas?
Old Nov 26, 2011 | 07:08 AM
zman17's Avatar
zman17
I don't know enough about transmissions to tell you. But it sure isn't going into OD. Most likely what you feel is TC lockup. And when you turn OD off it's just kicking out of lock up not OD itself.
Have you scanned it for codes?
Old Nov 26, 2011 | 05:33 PM
gdstock's Avatar
gdstock
No codes. In fact, while driving, I had MTG 2500 connected and glanced at it occasionally. Showed to be in OD, TC locked up.....
And 8uzzsaw, minimal load - three adults and luggage for one night. Nothing in bed.
Got pretty good at dropping tranny in just under 2 hours, but don't know what to look for. More research I suppose. 3200 rpm would explain gas mileage if it should be about 1000 rpm less at 70 mph.
Old Nov 26, 2011 | 06:44 PM
dlyter09's Avatar
dlyter09
3200 rpm at 70 mph on 3.55!! wow.. im not sure what could be the problem. i know at 70mph with 4.10's and 285's im at about 2400 or so.. I cant remember what it was before i swapped out the 3.55's though.. Seems high
Old Nov 26, 2011 | 06:49 PM
gdstock's Avatar
gdstock
I wonder if the wrong TC could cause this to happen? The box had the right part number on it, but TCs are seldom marked with part number....either that or I may have to drop it and pull OD off and check it out.
Guess this should be in tech section instead of general discussion. I was hoping that 3200 was normal .....
Old Nov 26, 2011 | 08:00 PM
Hahns5.2's Avatar
Hahns5.2
Doesn't matter what the scanner says. You need to push the OD button, if OD is working, it should drop out of OD and RPMs should go higher. If there is no change when you push the OD button, it's not going into OD.
Old Nov 27, 2011 | 09:48 PM
dipsherry's Avatar
dipsherry
Holy $hi7 i got almost 12 mpg in my truck.....i have 4.88 37s and i sat just over 2400 rpms @65
