Need Help figuring the problem with my truck
Old Dec 14, 2011 | 03:06 PM
one_of_a_kind_ram's Avatar
one_of_a_kind_ram
Default Need Help figuring the problem with my truck
Hey guys ive been on this site for awhile looking at all the information you guys have but this is my first actual post because im stuck trying to figure out this problem for the past 2 months...Ive got a 95 ram 1500 5.9 magnum and i keep hearing this strange ticking noise coming from under the hood. Now it only happens when i acceralate and when im braking it happens when the engine is hot or cold. I've replaced the water pump, tensioner assembly, idler pulley, fan clutch and put a new belt on...and still have the tick. Ive been told it could be a sticky lifter but since ive owned it i always do 3,000 mile oil changes with synthetic and lucas additive and i always buy premium gas at the same station every week...Any help or input would be great guys thanks
Old Dec 14, 2011 | 03:12 PM
kadetklapp's Avatar
kadetklapp
It could be any number of things. Off the top of my head-
Valve train noise- less likely than most people think
Vacuum leak
Bad spark plug/improperly gapped plug, but my bet is-
Cracked/leaky exhaust manifold.
Old Dec 14, 2011 | 03:13 PM
kejobe's Avatar
kejobe
Hows the plenum? Might be pinging. Could still be a lifter though.
Old Dec 14, 2011 | 03:18 PM
one_of_a_kind_ram
yea i thought it could be a leaky exhaust manifold to cause it seemed to look like the gasket was worn but the noise is a constant tick. And Kejobe do you know where i could buy the plenum kit if that is the problem?
Old Dec 14, 2011 | 04:14 PM
kejobe's Avatar
kejobe
A plenum leak wont cause a tick on its own. If there is a leak it will cause a vacum leak in the manifold, which in turn will cause pinging. The "repair kit" is available from Hughes engines or the plate from ebay. Read this, it tells all: https://dodgeforum.com/forum/2nd-gen-ram-tech/286307-end-all-be-all-plenum-thread.html
Old Dec 14, 2011 | 09:38 PM
gdstock's Avatar
gdstock
Use a stethescope to see if you can isolate where the ticking is coming from. But check the plenmum as it is a genetic problem on these engines.
