Lift Kit On!! (Pics)
Old Jan 4, 2012 | 05:33 PM
  #21
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by CharlieSheenWins
What backspacing would you recommend if I just did 33x12.50x16 on 16x10 right now? (cause honestly i dont have the money to pay for gears and installation and I dont really have a need for 35s) I would want the tires to slightly stick out past the fender too.
I can only tell you what mine is so here is the wheel I have. Note that my tire is narrower (albeit slightly) than a traditional 35", which is usually 12.5".
http://www.wheelsforless.com/detail.aspx?ID=3648
Old Jan 4, 2012 | 07:16 PM
  #22
CharlieSheenWins's Avatar
CharlieSheenWins
understood..i like that wheel!
Old Jan 4, 2012 | 07:32 PM
  #23
merc225hp's Avatar
merc225hp
Why are you going with a 16x10 wheel? 285/75r16 tire only needs a 8" rim so does a 315/75r16 tire. If you go 16x8 then your looking at around a 4.5 inch backspace, that would put the tire just outside the fender.
Old Jan 4, 2012 | 07:51 PM
  #24
CharlieSheenWins
I'm going with a 16x10 wheel because I want to go with a 33x12.50 tire.
So do you know what I would need for a 16x10 wheel?
Old Jan 4, 2012 | 08:02 PM
  #25
Wh1t3NuKle's Avatar
Wh1t3NuKle
Why stick with 16" wheels???
Old Jan 4, 2012 | 08:14 PM
  #26
CharlieSheenWins
hahaha idk i've always liked less wheel..I could consider a 17" wheel though
Old Jan 30, 2012 | 07:02 PM
  #27
97black_ram's Avatar
97black_ram
Hi CharlieSheenWins, I know this is post is a few weeks old but I finished installing a 3" top gun customz kit like yours with blocks and spacers. My question is did you have to change anything besides the shocks? I seem to have a little rougher ride than I did before. Thanks.
Old Jan 31, 2012 | 01:26 AM
  #28
97tn4x4's Avatar
97tn4x4
The spring rate is just probally different. Most lifts will make it ride a little stiffer.
Old Jan 31, 2012 | 02:37 AM
  #29
Wh1t3NuKle's Avatar
Wh1t3NuKle
exacto-mundo!
Old Mar 8, 2012 | 09:13 PM
  #30
Hylander7's Avatar
Hylander7
He didn't change springs, just added a spacer.
