Headlight cleaning suggestion
Old Feb 19, 2012 | 07:09 PM
Nereaga's Avatar
Nereaga
Just recently bought a product for cleaning the wife's headlights in her car and mine in my truck. It is called Restorem, even comes with a dvd to watch. $20 for the kit and it does two vehicles. Basically a two step thing with sanding in between with 2,000 grit wet sandpaper. Wife's were not as bad as mine, so hers are like brand new. We will see what it does an a tough lense...
I'll get before and after pics too!
Old Feb 19, 2012 | 07:11 PM
stewie01's Avatar
stewie01
Originally Posted by kejobe
That's kinda where I figured this was going. Although I wonder what taking the assembly off the truck and letting it soak in bleach or a cleaning chemical would do, if anything.....
Old Feb 19, 2012 | 07:26 PM
gertie240's Avatar
gertie240
You might not want to use bleach, it will dry out the plastic and may fog it worse. The electric buffers they sell help out alot no matter which way you use. rubbing compound works pretty good, or one of the kits they sell at the auto parts stores.
Old Feb 19, 2012 | 08:00 PM
stewie01's Avatar
stewie01
Alright. I'll try another brand cleaner, probably try the 3m stuff or something. Might just be time for new headlights.
Old Feb 19, 2012 | 08:40 PM
kejobe's Avatar
kejobe
The restore I used was Meguires. When I used the Turtle Wax I used it with a small air buffer. Guess I shoulda mentioned that earlier. Oops.
Old Feb 19, 2012 | 08:44 PM
stewie01's Avatar
stewie01
Well I put some elbow grease into it and it didn't work too well. I think there is a buffer around here somewhere...
Old Feb 19, 2012 | 08:50 PM
gertie240's Avatar
gertie240
Are you going to take them off the truck? If not, dont forget to tape off the surrounding areas. Those buffers can get away from you. dont ask me how I know. LOL
Old Feb 19, 2012 | 08:54 PM
gdstock's Avatar
gdstock
3M Perfect It 3000 compound and a buffer. Remove from truck and hold it securely somehow before hitting with buffer. Then use some 3M swirl Remover (can't remember product number..)
Old Feb 19, 2012 | 08:58 PM
stewie01's Avatar
stewie01
Originally Posted by gdstock
3M Perfect It 3000 compund and a buffer. Remove from truck and hold it securely somehow before hitting with buffer. Then use some 3M swirl Remover (can't remember product number..)
3M it is! I'll see what I can find around the local part's house.
Old Feb 19, 2012 | 09:06 PM
Nereaga's Avatar
Nereaga
http://www.medsproducts.com/retail_p.../restorem.html
