2nd Gen Ram Picture thread!!! Pic whore's unite.
Old Dec 2, 2013 | 11:59 AM
  #1391
dlyter09's Avatar
dlyter09
First winter pix.
Man I almost forgot how good your truck looked man.. Still nice as always
Old Dec 2, 2013 | 12:25 PM
  #1392
merc225hp's Avatar
merc225hp
Thank you
Good see you around!
Old Dec 2, 2013 | 12:35 PM
  #1393
dlyter09's Avatar
dlyter09
Yea it has been some time since I was around.. Working my *** off the past couple months and things are slowing down a bit so I have some extra time..
Old Dec 2, 2013 | 02:33 PM
  #1394
Jimythefan's Avatar
Jimythefan
Truck looks great Merc. What do you do to keep rust at bay during salt season?
Old Dec 2, 2013 | 02:50 PM
  #1395
merc225hp's Avatar
merc225hp
Thank You
Well this year I am trying what you use fluid film. I have tried lots of stuff over the years from rubber coating to just oil, to rigorous washing. Right now I have three test spots using POR-15 on the frame if it works like I think it will, it be used on the whole under side, cleaned and painted with that when the body work is done.
Both front fenders are toast so is the box wheel arches. I lost control three years ago when they started using some liquid stuff on the roads not nice at all. I had plans for body work this summer but well I got side tracked installing the 60's, long arm's, xcase indexing ring and so on. I have some auto body parts, but not installing until spring just not worth it to do it now.
Old Dec 2, 2013 | 02:59 PM
  #1396
Jimythefan's Avatar
Jimythefan
I've had good luck with the fluid film. The little bit of rust that was on it when I bought it hasn't spread, so I'm optimistic so far. Going to pull the chrome wheels this week and touch up a couple spots with fluid film.
That pic you posted shows a clean truck. The rockers and doors look great. It's one of my favorites on here.
Old Dec 2, 2013 | 03:11 PM
  #1397
merc225hp's Avatar
merc225hp
Thanks again.
I have high hope for the fluid film, I followed your lead inside the doors all that stuff, did some of the underside of the cab as well. I am also trying it on my wheels so far so good.
So do you wash it off at anytime and re-coat or??? fill me in please.
Well your's is one of my fav trucks on here, sharp truck always has been.
Most of the cab is mint zero rust, same goes for the doors, other than one cab mount. Trying to find a new one (cab mount) is not gonna happen I am looking for a used cab these days to cut one out of. No I can't just build one insurance reasons.
Edit:I should add I wax it with a top wax,I try to get two coats on it before it gets to cold, and if I get a chance I wax it in the winter as well (yes outside).
Old Dec 2, 2013 | 03:45 PM
  #1398
Jimythefan's Avatar
Jimythefan
Mine gets 2 coats of good wax in late November too.
I go crazy with stuff. I spray the snot out of the frame and the underside of the body. Suspension, steering parts and everything else I can think of. I try to get some into the frame area where the front sway bar mounting bolts are. Moisture accumulates there. I stick the nozzle/tube thingy right into the cab drains and spray in all directions to coat the inside of the rockers and body mounts. I do the same under the bed and inside the tailgate areas. I pull the plastic rear liners, reach up as far as I can under the bed and spray from both directions to get along the wheel wells. My flares come off easily so I can do along the inside fender lips. I spray along the sides of the body up a short ways along the cab corners and front of the bed seams.
After letting it settle in for a week or so. I gently wash the outside of the truck to get rid of any excess and call it done for the season. The stuff never really dries and migrates into areas where the spray couldn't reach. Come spring I give a good wash down to the whole truck with a pressure washer and so far it's been good.
After it settles in and dries for the most part. When you wash the truck you can use a soft towel to wipe the nicer areas down and the stuff acts like regular car wax.
Old Dec 3, 2013 | 07:27 AM
  #1399
oxymoron29's Avatar
oxymoron29
^Good to see that some one else "gets it". I also undercoat the hell out of all my vehicles. No paint / rubberized coating / POR-15 is going to offer the same lasting protection.
Old Dec 5, 2013 | 07:27 PM
  #1400
Derick C.'s Avatar
Derick C.
Had to hook up the trailer so I can go pick up our new furniture tomorrow.
Attached Thumbnails 2nd Gen Ram Picture thread!!! Pic whore's unite.-truckandtrailer_zpsf506366b.jpg
