Gun rack solution.
Old Feb 19, 2013 | 04:45 PM
D_Boosta's Avatar
D_Boosta
Default Gun rack solution.
I myself came to dodge forums looking for gun racks that would work with my ram. (Other than roof mounts)
So I looked every where online and couldn't find one I liked or that would fit my window.
So I took it upon myself to make/ rig something to work. Found my solution at walmart. I went to walmart and found in the car area some mounts that are used to mount on an atv. For $20.
If your willing to put in the work its well worth it. You have to take off the plastic between your carpet and door. And take off the weather stripping then unscrew the panel where the seat belts are (and the plastic piece on the floor behind your seat If you have one and take it out) then unscrew the back panel and remember that there's three screws at the base of the back panel under the carpet. Then drill your four holes for the bolts. (Before you take anything apart line up then mount and use a marker to put dots where you want to drill) that's it put everything back together.
Old Feb 19, 2013 | 05:23 PM
gdstock's Avatar
gdstock
Did you take photos?
Old Feb 19, 2013 | 06:11 PM
kejobe's Avatar
kejobe
I call B.S. No pics, it didnt happen.
Old Feb 19, 2013 | 06:16 PM
Pretty useless post without pictures.....
Old Feb 19, 2013 | 06:32 PM
guzman's Avatar
guzman
Lets see it full of LongGuns so we can approve.............or not :-)
