e bay headlights and tail lights
Old Feb 23, 2013 | 08:37 AM
rickit's Avatar
rickit
Default e bay headlights and tail lights
are they of any quaility? looking at buying some to replace mine
Old Feb 23, 2013 | 08:43 AM
kejobe's Avatar
kejobe
Probably not. But without knowing which ones your looking at, cant say for sure. But, 99% are junk and not worth the money.
Old Feb 23, 2013 | 08:50 AM
stewie01's Avatar
stewie01
If you're looking for headlights, http://www.am-autoparts.com/2001/Dod...eadLights.html
I ordered these and installed them a couple of days ago, and they're great. I put PIAA Extreme Whites in them and they're really bright, even without relays.
Amazon.com usually has stuff cheap too
Old Feb 23, 2013 | 09:25 AM
Grolli's Avatar
Grolli
I purchased these off ebay about 8 months ago. Old headlights were yellow, and could not see at night. They fit right in. The rears have about 1/16" gap between the light and the frame on the outside fender wall. Other than that, I would recommend them as a replacement.
http://www.ebay.com/itm/94-01-DODGE-...5083f3&vxp=mtr
Old Feb 23, 2013 | 11:07 AM
gdstock's Avatar
gdstock
I bought headlights and tail lights for my Ram. Headlightswere great and have been in about a year and a half or so. Tail lights looked good, but after about a year, the bulbs melted the plastic on it. Seller replaced, but I installed a different set that I do not like as well, but are functioning well. I still have the replacement tails, but looking for LED bulbs to eliminate heat issue.
Old Feb 24, 2013 | 10:12 AM
Grolli's Avatar
Grolli
Just remember, use of LED bulbs require either a different flasher relay (still cant find the right one myself) or the installation of a resistor in-line with the bulb you are replacing. This avoids the "hyper bulb flash" you see on many cars/trucks. Resistor must be attached to metal due to heat created.
Had a buddy install the resistor inside his fender walls, his paint changed color due to heat.
