Handling?
Old Sep 18, 2013 | 06:42 PM
98Ramboy's Avatar
98Ramboy
Default Handling?
Looking to try and make my truck handle better. Does anybody have any advice? When I changed the shocks, that made the ride a little stiffer but not too noticeable. Anybody know what I should invest in?
Old Sep 18, 2013 | 06:50 PM
Ham Bone's Avatar
Ham Bone
if you want handling you should sell it and get a car
if you want better steering you have a couple options
clipper77's Avatar
clipper77
Upgrade the gear box to a Borgeson (sp?) or Red Head.
http://dodgeramsteeringstabilizer.com/
These steering stabilizers are good too.They bolt into the existing sway bar mounts and reduce frame flex, along with stabilizing the gear box and pitman arm.
Note: the upgraded gear box and steering brace will only function correctly if all other steering/ suspension components are good.
Old Sep 18, 2013 | 07:03 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Stiffer sway bar, larger wheels with shorter tires for starters.
Old Sep 18, 2013 | 07:15 PM
redheadhunter21's Avatar
redheadhunter21
Take the stacks off, drop the truck 2/4 and put on bigger rims with lower profile tires, and a rear sway bar.
That's a good start
Old Sep 19, 2013 | 08:20 AM
What exactly are you looking for? It's a truck, it will never ride like a car. I would start with a basic inspection of your current suspension components. See whats worn and replace. Upgrade bushings to poly, bigger sway bar plus the other things mentioned.
Old Sep 19, 2013 | 08:39 AM
ChillyPhil's Avatar
ChillyPhil
I plan on getting that Rock Solid Ram kit when I put my 5" lift on just to be safe. And dual steering stabalizers when I get 35s.
My rear Hydro 7000s I just got a month ago been blowned two weeks after I got them. Must of got Shi*ty ones or something.
