Looking at a 96 dodge ram 3500 v10 4 x4
Old Oct 25, 2013 | 09:58 AM
  #21
Wh1t3NuKle's Avatar
Wh1t3NuKle
Originally Posted by ebxgsxr
congrats on the purchase....where are the pictures?
ditto!
Just in case, your wheel lug pattern is 8x6.5".
Old Oct 25, 2013 | 10:30 AM
  #22
If you bought a truck, we need to change the title of this thread and if you want to turn it into a technical question thread for your new truck we need to move it to the tech section......or......start new threads on issues so it's easler for other members to search for stuff instead of burying your tech questions inside a general discussion thread on "looking at a truck" .....
  #23
sbrodacz's Avatar
sbrodacz
Originally Posted by Wh1t3NuKle
ditto! Just in case, your wheel lug pattern is 8x6.5".
Thank you. I was going to ask that.
Old Oct 26, 2013 | 09:08 AM
  #24
sbrodacz's Avatar
sbrodacz
Went and got an oil change yesterday since there was an oil leak. They said there was a leak from the main seal but it wasn't bad. I have a ton of oil on my driveway this morning. Looks like I am going to have to drop the truck off at the mechanic. I hope everything else is ok.
Old Oct 26, 2013 | 11:48 AM
  #25
clipper77's Avatar
clipper77
Maybe the drain plug or filter were not tightened all the way after the oil change?
hope it's nothing major.
Old Oct 26, 2013 | 01:44 PM
  #26
sbrodacz's Avatar
sbrodacz
Originally Posted by clipper77
Maybe the drain plug or filter were not tightened all the way after the oil change? hope it's nothing major.
I don't know. The oil change place said it looked like the main seal was leaking. Just my luck.
Old Oct 28, 2013 | 10:52 AM
  #27
sbrodacz's Avatar
sbrodacz
Mechanic just called. Truck needs a new oil pan. I just hope the truck wasn't driven that much with low oil. It ran good and strong so I'll try not to worry about it too much.
