t v cable
Old Nov 24, 2013 | 09:46 PM
catota's Avatar
catota
Default t v cable
searched and could'nt find it.On throttle body there are 2 upper cables and a lower one which i believe is the tv cable.there is a black plastic clip, which on my 2001 1500 5.9l is broke off do i have to replace the whole cable or can you but the clip
Old Nov 24, 2013 | 09:59 PM
95' 360 Ram's Avatar
95' 360 Ram
From what I heard, you will need to replace the whole cable. Check a local junk yard for them, make sure that it has the same throttle body as yours. In my case, I had just the clip break off clean and just got a dremel to drill a new hole so that it would clip back on.
Old Nov 24, 2013 | 11:19 PM
mibzzer15's Avatar
mibzzer15
Yeah if the click broke off you have to replace the whole cable, that is unless you can rig it up so it was in the same position before and it stays there.....
